Cornet2 LED substitution
0 Members and 1 Guest are viewing this topic. Read 2364 times.
G E
« on: 7 Feb 2013, 02:55 pm »
DigiKey is back ordered  on the substitute for 754-1235-ND, the 754-1548-ND and I don't want to split the order to Mouser.
I found a couple of possible alternates.  They are not superbright versions and the forward voltage for Red is 2V instead of 1.95V of the 1548 and original spec 1.85V.
http://www.digikey.com/product-search/en?x=0&y=0&lang=en&site=us&KeyWords=754-1232-ND
Here is another option, the 754-1471-ND
http://www.digikey.com/scripts/DkSearch/dksus.dll?WT.z_header=search_go&lang=en&keywords=754-1471-ND&x=11&y=21&cur=USD
Both of these have the same form factor as original spec.
Will these work?  Appreciate your input!
ge
poty
hagtech
Re: Cornet2 LED substitution
« Reply #2 on: 7 Feb 2013, 10:37 pm »
Try this one: 1080-1109-ND.
jh
G E
« Reply #3 on: 8 Feb 2013, 08:04 pm »
jh
Thanks, Jim. Order placed with DigiKey last night and it is already on the way!
The Lansing case and auricaps arrived today, your PC board showed up yesterday.
So, I will be in business shortly.
hagtech
« Reply #4 on: 8 Feb 2013, 11:24 pm »
It's a lot of work.  Take your time and have fun with it!
jh
