Tips to help the BDP- cables
0 Members and 1 Guest are viewing this topic. Read 794 times.
fine tunes1
« on: 6 Feb 2013, 12:39 pm »
Hello I have found going through my Verizon router multitasking that I sometimes get drop outs nd loose. One or. Freeze up. I switched from a cat 5 cable to a cat 6 A cable a means augmented your band width is much higher and up to 10 x the information can go through.i have found this a great solution .
My freind works at IBM and said this cable is now a standard in most departments, and these cables are not that much.i went to cables to go. $5.00 for a $7 ft. Even in 50 ft length not much more then the cat 5 .
Good luck.
underdawg
Re: Tips to help the BDP- cables
« Reply #1 on: 6 Feb 2013, 03:45 pm »
I am going to try that myself. Thanks for the info.
