Refurbed Mac Mini
0 Members and 1 Guest are viewing this topic. Read 1228 times.
Jonathan
Refurbed Mac Mini
« on: 2 Feb 2013, 03:06 pm »
Planning to use a Mac Mini for a computer-based system. Any compelling reason(s) either to go with (or not) the $469 refurbed Mac Mini? Thanks in advance. -Jon
Here are the specs:
2.3GHz dual-core Intel Core i5
L3 cache    3MB shared
Memory    2GB of 1333MHz DDR3 SDRAM; supports up to 8GB
Hard drive    500GB 5400-rpm Serial ATA1
Graphics    Intel HD Graphics 3000 processor with 288MB of DDR3 SDRAM shared with main memory2
Ports    Thunderbolt port, One FireWire 800 port; four USB 2.0 ports; HDMI port; SDXC card slot, VGA output (using optional adapter)
Audio    Audio line in minijack (digital/analog); Audio line out/headphone minijack (digital/analog); HDMI port supports multichannel audio output; support for Apple iPhone headset with microphone; built-in speaker
Networking    Built-in 10/100/1000BASE-T Ethernet (Gigabit)
Wireless    802.11n Wi-Fi wireless networking3; IEEE 802.11a/b/g compatible; Bluetooth 4.0 wireless technology
Size and weight    Height: 1.4 inches (3.6 cm)
Width: 7.7 inches (19.7 cm)
Depth: 7.7 inches (19.7 cm)
Weight: 2.7 pounds (1.22 kg)4
shadowlight
Re: Refurbed Mac Mini
« Reply #1 on: 2 Feb 2013, 04:33 pm »
My understanding is that refurb mini purchased through Apple store has the same warranty as new product.  I do not see any reason not to purchase refurb and save money.
srb
« Reply #2 on: 2 Feb 2013, 04:56 pm »
Considering that you are getting the older model (2GB RAM / 2.3GHz i5 / USB 2.0 / Intel HD Graphics 3000) and that Apple will charge you sales tax, you might want to also consider the newer model (4GB RAM / 2.5GHz i5 / USB 3.0 / Intel HD Graphics 4000) from B&H Foto & Electronics for $565 shipped.
Depending on your sales tax rate, it might only cost you ~ $50+ for the brand new more capable updated model.
simon wagstaff
« Reply #3 on: 3 Feb 2013, 03:05 pm »
the specs will be just fine. I have a much older mac mini core solo that works well as a music server.
I have basically only bought refurbs from the Mac store, it is just about the only way to save money. However, I don't think the lower price on non-current models is worth it. Likely much better to spend the extra hundred bucks or whatever and get the current model. I am waiting for the current mac minis to show up on the Apple store. That's when I will pull the trigger.
almonduck
« Reply #4 on: 3 Feb 2013, 03:52 pm »
I've been following the refurbished Minis also. I'd also wait for the current Oct. 2012 model to come back up. At only $509, it's only a bit more and you get a few of the new upgrades. The disapear quick.
