What is the Best No-Break??
0 Members and 1 Guest are viewing this topic. Read 1211 times.
« on: 31 Jan 2013, 11:44 pm »
Iam using a small APC BE600 12V/7A battery which Iam using now with a 9A battery, but the power on push button is a micro switch, not a reliable part, as it loose after afew months.
In your experience what is the best No-Break do you would suggest??
JEaton
Re: What is the Best No-Break??
« Reply #1 on: 5 Mar 2013, 11:16 pm »
Why would you have to power on/off a UPS? That's certainly NOT how you'd want to shut down a computer connected to one.
Bizarroterl
« Reply #2 on: 6 Mar 2013, 04:13 pm »
My thought too.  I've bought/managed many UPSs and I haven't used a power switch on one more than a dozen times.
« Reply #3 on: 6 Mar 2013, 05:05 pm »
Once one press the power on button the unit is working and the battery too, they had a limited MTBF life, not to mention surges and low tension.
When I power off the PC I also power off the no-break, I dont want let it on for safety, save the battery and electricity bill;
It is this unit pictured below, the unreliable button is the round at far left :
