Compare SOA to Ampzilla 2000
0 Members and 1 Guest are viewing this topic. Read 2745 times.
zybar
« on: 27 Jun 2004, 12:57 pm »
Brian,
Since you have used both in your system, can you describe the differences between the 2 amps?
From what I read about the listening session yesterday, it sounds like you are currently using the SOA full range on the 40's.  Just based on the "stats" I never would have thought it could drive the 40's full range with good results.
Thanks in advance for your thoughts.
George
sbcgroup1
SOA
« Reply #1 on: 29 Jun 2004, 02:31 pm »
Yeah, I'd like to get an answer on that too....
Plus, what is the price on a SOA?
-Ed
Brian Cheney
    • http://www.vmpsaudio.com
SOA
« Reply #2 on: 29 Jun 2004, 04:07 pm »
Price of the Son is $3250.
The Son sounds cleaner and punchier than the monoblocks which have more bottom end, however.  This should change with elimination/bypass of the input selector toggle switch, which the Son lacks.  Bongiorno uses a pro-style bal/unbalanced auto-switching input that accepts phone plugs and XLR's.  He supplies a phone-to-RCA adapter which I recommend NOT be used.  Have your cable guy retip your IC's with good quality phone plugs.  Wayne at Bolder did a good job on mine.
John Casler
Re: SOA
« Reply #3 on: 29 Jun 2004, 04:07 pm »
Quote from: sbcgroup1
-Ed
Presently AMPzilla 2000 is $5500 for a monobloc pair and The SON of AMPzilla is $3250
zybar
« Reply #4 on: 29 Jun 2004, 04:56 pm »
Brian,
Have you tried running SOA on mid/tweeter and one the QSC amps on the woofers?
Sounds like it might give better performance than the monos and be cheaper as well.
George
John Casler
« Reply #5 on: 29 Jun 2004, 05:07 pm »
George,
As an after thought, In speaking with James at the CES, I remember him telling me about the "adaptor" he had for the SON to allow the outputs to be adapted to either balanced or single ended.
I could be wrong, but I think he said he was thinking about doing the same for the A2K, which would eliminate the switch B is refering to.
Juan R
« Reply #6 on: 29 Jun 2004, 10:18 pm »
Brian      What about soa for mid and high and mono for the bass? I ask because I have the mono.
Brian Cheney
soa
« Reply #7 on: 29 Jun 2004, 10:57 pm »
That's the combo I use on the RM/X!
zybar
« Reply #8 on: 29 Jun 2004, 10:59 pm »
So I repeat my earlier question...
Brian, have you tried the QSC on the bottom and the SOA on the mid/tweeter?
I can't afford to have $5500 bass amps.   :(
George
Marbles
« Reply #9 on: 29 Jun 2004, 11:21 pm »
Quote from: zybar
George
George, I wonder how the K2 would be on the bass?
zybar
« Reply #10 on: 29 Jun 2004, 11:24 pm »
I am going to find out over the next 5 days.   :lol:
Since I haven't sold the QSC PLX3402 yet, I will try that as well.
Since both have volume controls, I should be bale to match the output of the Rowlands in a passive bi-amp setup.
George
James Romeyn
« Reply #11 on: 30 Jun 2004, 04:25 am »
From what I've heard the killerest setup might be horizontally biamped SOAs, $6500pr.  Depending on the source, with the SOAs standard 33k input, it might be better to order them with the optional higher input Z.
The three channel (when/if it arrives) + the SOA should fly off the shelves.
tkp
« Reply #12 on: 30 Jun 2004, 04:31 am »
Quote from: RibbonSpeakers.net
Jim,
I am not sure the SOA input impedance can be changed to higher than 33Kohms.  This has to do with the sharing of SE and XLR input.  This was one of the reason why the SE gain of SOA is stuck at 26db and cannot be change to 32db to match the Ampzilla2K.
