0 Members and 1 Guest are viewing this topic. Read 5091 times.
...when I put his old Amadeus into my system (replacing the Classic 1) the differences were fairly mind blowing... the person who bought my Amadeus replaced a Classic 3 and I think I saw a post from him saying the Amadeus is better.
I'd also suggest taking a look at the Townshend Rock 7. There is a thread here where I compare it to the Amadeus, also an excellent table. The Classic is also a nice suggestion. Haven't had one in my system, but liked it in a friend's system (too much unfamiliar gear there to be able to compare it to the turntables I have had in my system, but that set-up with the Classic, an ARC preamp and powered ATC speakers did sound very nice). Avid's new table also looks very interesting. TONEPUB has reviewed it. Where are you located? Any possibility of auditioning any of these?
Hey! Last year I heard the Townshend Rock 7 at Wes Bender Studio here in NYC. I did spent sometime with it spinning my own LPs I bought over. Well, at first I thought the front damping well would be annoying but after a few time of use I got used to it. I was impressed with the sound, it was... well rock steady and rock solid... pun intended. I'm not not looking for a new TT right now and its price tag is a bit more than I can afford right now. But if I will be looking for a new TT I will definitely put this on my list and save money for it. It was one of the more memorable TT I've encountered. Anyway, if you are in NYC area or near by do check it out at Wes'....http://www.wesbenderstudionyc.com/townshend-audio-turntables/Take care,Buddy
Yeah, I got very lucky and bought the only Rock 7 I have ever seen for sale used from a dealer who got it on trade-in and priced it amazingly low (including a Rega arm, less than I paid for my Amadeus). It is a superb table, and unlike the Amadeus, it allows you to obsess over potential tonearm upgrades (for better, for worse). Here is the link for the thread where I compare the Rock to the Amadeus:http://www.audiocircle.com/index.php?topic=105495.0Not having a Rock dealer nearby, I have talked with Wes about getting a Rock clamp (not included with mine) and he seems like a very solid guy. Yes, those of you in the NYC area, should hit up Wes and check this table out.
really, everything was better in my opinion. sound wise there was nothing the VPI did better than the Amadeus. one of the biggest differences was in the bottom end, much better bass for sure. overall, a much more organic 3D analog sound, which for me is the whole point of having a TT.
Soundsmith Strainguage comes with phonostage and a pick up. I think you can get a TT and arm to go with it all under your budget if you go used. I would compare the sound to be in the same league as what I get from my newly upgraded digital featuring the DAC2x. It should be able to hang with MA-1.
