0 Members and 1 Guest are viewing this topic. Read 11875 times.
Can't see that there would be a problem with decay when you have something as high speed as the Ncore. Or micro detail on an amp that is basically all about micro detail. Yeah, those are basically some of the main strong points of the amp, lol, so that would be kind of strange. To Clifford Brown, which state do you live in? If you're in Washington you're welcome to come listen.
Yes... I was about to buy the STI-500 for Maggies and other inefficient speakers, because the reviews / comments indicate they compete with the very best. But, I learned W4S is about to update their older amps to use the newer ICE modules they use in the new iMINT over the next year. So, I decided to wait until then. In the meantime... I ran across the Class D Audio SRS-470C amps - which get even better reviews / comments than the W4S amps... and... I bought one to try out. We'll see how it does... but... I expect it will prove to be the "Value-priced, Giant-Killer" that the reports say it is. I prefer the sound of tubes also... but... tube amps with sufficient power to drive Maggies well... cost a "Kings Ransom." If I think I want more "tube distortion" to improve the sound, I'll use a tube pre-amp, or tube buffer - starting with my Monarchy Audio M24 Tube DAC / Line Stage. We'll see...
Very interesting. I wonder if this is the new W4S amp Gradofan mentions:http://app.audiogon.com/listings/solid-state-wyred-4-sound-mamp-250wpc-mono-block-fully-balanced-2013-01-29-amplifiers-93422-atascadero-caIt doesn't appear to be on their site yet.
Interesting. I don't think it applies to the Ncore's switcher though, because, I've run several sets of speakers on these Ncores now, other than Maggies, and there wasn't anything you are describing. They are as fast and lucid as a scalded ape. About 99% of the reviews are also "best amp I've ever heard regardless of topology", so I dunno man? *shrugs*. Some of the guys on this very forum replaced very expensive, modern tube amps with them.Anyway, interesting point about old tech switchers. The switcher in the Ncore is a modern marvel. It even provides its own power conditioning, to the exclusion of any external devices.Either way, the OP is gonna get to swing by in about a month and come check them out. He's also getting Magnestand mod on the MMG too, so he'll be able to see mine.
I would also note the high frequency anomalies were not very evident on MMG's, but were more pronounced on dynamic speakers that have much less HF rolloff that the MMG's.
Yeah, I don't buy it though. I've read several cases over on the diy thread and elsewhere of people having such an issue and then they go and change some cables or something and holy moly problem solved, incredible amps, etc.
I've had other speakers in here as well and don't hear any, what did you say. There are people running them with very high efficiency speakers and love them.
I also don't really have stacks of gear inbetween my source and my amps. Just a volume knob, basically. Maybe you had some distortion in your system, the Ncores would amplify that.
So far these amps have taken on and reviewed against much more expensive stuff, and against other topologies as well, and has consistently come out as a top performer. .... There are very, very few negative reviews on this amp, let's be honest now. Most of them are positive and quite impressive to read, actually, the gear some of these people have owned. The only negative ones I've come across are found here. Those were also predictably received. So I take comments with a grain of salt, especially things like "lack of detail." It just sounds made up.
Minor point, every response curve I've ever seen of the MMG's shows them to be essentially flat to 20 kHz.
