0 Members and 1 Guest are viewing this topic. Read 3087 times.
Hey John,Glad to see you found your happy place again Gotta love the simplicity of an integrated, in fact I'm debating really hard about simplifying one of my systems and going with an integrated. Right now that system is a tubed pre, separate phono pre, TT, SB3, DAC, big honkin' monoblocks and Tannoy's. I've got a HH Scott 299 that is 90% restored sitting on the shelf. If I'd just get off my duff and finish the power supply, I could put her back in service I'm even debating getting rid of the Tannoys for a stacked pair of Advents or some Dynacos.
Hi John & Everybodies...Know how exactly how you feel. Due to an extensive work schedule that often comes with plenty of travel, I can go for long periods without either listening at all or only listening to digital as a convenience. Although, I've got some very good digital equipment, when I finally get the chance to turn on the analog rig, sit down and actually LISTEN to vinyl, I'm still startled... in a very good way. Ahhhh... Sounds good!
Yup - Digital is SOOO GOOD at such attractive price points now
A logistical question (I am thinking of a well shelf behind my rig). How far over do you have to reach to play a record (i.e. how close is the equipment to the back wall)?Also, are you using damping fluid in the tonearm?Paul
\It's a Denon DL-160vdH on the VPI these days.....it doesn't seem to benefit from damping fluid on prior trails with it. If it was a Grado, you bet there would be fluid in that pivot Cheers, John
