mac mini component video out adapter?
0 Members and 1 Guest are viewing this topic. Read 4330 times.
simon wagstaff
« on: 27 Jan 2013, 01:03 pm »
Silly, easy quick question. I have a mac mini core solo, kind of an older one. I am looking at getting a new tv, it only has two HDMI inputs and one component  video input. I use the mini as a server and currently have a DVI to VGA adapter hooked up to the VGA input on my old tv. Can i get just and adapter cable to run from the DVI to component video or do i need some sort of converter box?
mcgsxr
Re: mac mini component video out adapter?
« Reply #1 on: 27 Jan 2013, 01:26 pm »
I have an older Mac Mini myself, and have successfully used a DVI-HDMI adapter to a new display.
Is that what you mean?
simon wagstaff
« Reply #2 on: 27 Jan 2013, 03:00 pm »
Yes, but I need to go to component video, not HDMI
wshuff
« Reply #3 on: 27 Jan 2013, 03:17 pm »
mcgsxr
« Reply #4 on: 27 Jan 2013, 03:44 pm »
Sorry, I saw that the display had 2 HDMI's and dove in!
simon wagstaff
« Reply #5 on: 27 Jan 2013, 04:26 pm »
That audio authority device is $330.00. Not really practical. There are many DVI to component video simple adapter cords, a couple of them are on Amazon for a penny and 6 bucks shipping. if the signal is sort of the same and all it takes are the connectors then I am thinking I should be able to just get one of these adapters to connect the video out from the Mac Mini to the component input of the TV. I don't really care too much about the quality, i will just use the monitor to select tracks for a playlist etc.
Thanks for your replies!
wshuff
simon wagstaff
« Reply #7 on: 5 Feb 2013, 01:01 pm »
I can report that a simple vga to component adapter cable will not work. Next up I will try a DVI to hdmi adapter cable and run the computer video through my home theater receiver. I just need to be able to select tracks and do simple things with the mac mini. Hopefully this will do the trick.
lokie
« Reply #8 on: 5 Feb 2013, 01:18 pm »
How are you going to handle audio? Do you anticipate latency issues w audio and video?
Please let us know how your execution works out.
simon wagstaff
« Reply #9 on: 10 Feb 2013, 01:34 pm »
I am using the mac mini strictly as a music server. I use the toslink digital output for stereo sound, only. Oh, I suppose I can get DTS out that was as well, hi rez audio up to 24/96 but not DSD or DVD-A type files. All I need is some sort of video monitor output so i can use a mouse to select tracks and make playlists etc., move files around. I have it all hooked up but haven't tried it yet.
there is one new annoying thing. I just got a very nice Panasonic plasma TV, 55" on sale with a coupon at Costco for $750.00. Seems when I try to select one input for the TV and one for music through my blu ray player the tv causes the inputs to switch along with it. i have to put my hand on the side of the remote so the TV doesn't see the signal.
Also, I have everything plugged into a Monster power conditioner. I am guess the turn on sequence is now not correct, I need to turn everything on and then turn the receiver off and on again to get the Denon link to lock on.
simon wagstaff
« Reply #10 on: 5 Mar 2013, 01:57 pm »
Just going to confirm that using a DVI to HDMI conversion cable I get good video output from the mac mini, into my home theater receiver HDMI input and then from there to the TV. Of course, i don't get audio that way, still using the toslink audio output from the mac mini. all is good.
