0 Members and 1 Guest are viewing this topic. Read 2418 times.
Forgive the dumb question (I'm just getting started in analog): I just pulled the trigger on a Traveller and a Clearaudio Aurum Alpha II cartridge. The cartridge weight is 10 grams, which is (?) at the heavier end of the spectrum. Am I OK? I just want to be sure. The cartridges I see paired with the Traveller are generally 7-8 grams or less (Ortofon 2M, Dynavector 10x5, etc.) and VPI bundles it with the Grado Gold, which is only around 4 grams (!)
The Traveller arm spec is - cart weight 4 - 12g. You should be fine balancing the arm.Cart compliance is 15cu, same as series 1. You should be fine with the arm mass (12g), also. Make sure your Traveller has a pebble paint finish, rather than glossy. The first batch with glossy finish have a defective tonearm collar, or they might be missing that part, I'm not sure. If it's glossy, it should be easy to exchange. Good luck with it. Not a dumb question at all. Welcome to analogue,neo
Can you please elaborate on the defective tonearm collar? I have an early traveler that would appear to have a glossy finish.
