Rush 2112 DVD-A
0 Members and 1 Guest are viewing this topic. Read 1497 times.
Russtafarian
  • Typical reaction to the music I play
Rush 2112 DVD-A
« on: 25 Jan 2013, 07:06 pm »
Just got this the other day.  The 5.1 mix is really good!  The opening 2112 Overture sounds big, spacious and punchy with loads of depth and detail.  Alex's buzzing amp is clearly audible in the back of the sound stage (for better or for worse) and every guitar and bass lick is clearly rendered.  And the drum sounds... let's just say that air drummers will get a serious workout listening to this.  What a blast!
This is the best sounding Rush DVD-A I've heard, clearly better than Moving Pictures or Signals.  The Signals 5.1 mix is pretty good, but the overall sound quality of that album is crippled from being recorded in stone-age 14 bit digital.
Russ
rooze
Re: Rush 2112 DVD-A
« Reply #1 on: 25 Jan 2013, 07:31 pm »
Thanks for the heads-up!
I was looking at this on Amazon a couple weeks back, there seemed to be 2 versions, one Blue-Ray the other DVD-A??
Is this what you have http://www.amazon.com/2112-5-1-Audio-Deluxe-Edition/dp/B00A2BTCM4/ref=sr_1_4?ie=UTF8&qid=1359142076&sr=8-4&keywords=rush+2112
I can't play Blueray but DVD-A is good  :)
Russtafarian
Re: Rush 2112 DVD-A
« Reply #2 on: 25 Jan 2013, 09:57 pm »
Yup.  That's it.
