0 Members and 1 Guest are viewing this topic. Read 8738 times.
I have followed your threads on both forums and I think what you have gleaned is that it is all personal preference and nothing else. I prefer the high end vintage and some prefer the new and I like Neobop have owned both. We all have made our choices based on what we think is best. The only people I know of that have the ability to try both as the result of their occupations would be Tonepub, Fremer and Art Dudley and they haven't chimed in yet and probably won't. So you are left to draw you own conclusions just as I and others have.
At this point I interpret most of the answers to equal 'we don't know', which is fine. I have gleaned enough from posts here and there and at Akarma to reach my own conclusions. This is not a question that requires the least bit of zen.
I've gleaned that an Audiomod tonearm kit and a <$500 table to mount is a good place to start.
Your initial question requires quite a bit of qualification for a meaningful answer. All things are never equal."I think that's about right, but you posted pics of a couple of vintage Yamahas and talked about a DP-59L. They're quite a different proposition. There might be a few decent arms less than the audiomod kit, depending on what cart you plan to use. It will probably be harder to find a good table less than $500. Dealers snatch them up, put an old arm on, and sell them for big bucks. There's an SP15/MMT w/fancy wood base on Audiogon now for $1250. That's what I was going to pay for an SP10 MK2 a couple of yrs ago. I have a few tables that take seperate arms. It helps if you can make armboards and do minor repairs. The table is more important than the arm. As I was trying to tell you, decently priced tables with or without arms, are getting rare. Good luck to whoever is doing this. Maybe they can luck into a private sale.neo
I'm not sure I can qualify my question any more than I have. In fact based on most of the responses I don't think it would matter if I did. The pics I provided were just examples and I implied as such and I included tonearms as a factor in the OP. I understand what you are saying about availability and it's noted.
Your question is too general for a simple answer. You can qualify it further with specific examples. You seem to think that performance on a 20 or 30 year old table should be the same as new. I was trying to run down some of the considerations. Sorry I got involved.neo
Tonepub - have you ever played with an Amadeus? I've never seen you mention them before.
With a little diy, I think it's possible. Take a visit to Lencoheaven to see some of the tables built for under $1000. You'll find quite a few examples of <$1k builds outperforming some big name decks. You can also check Arthur Salvatore's site for some comparisons between his Lenco and more high end tables.
Please understand, I hear what you've been saying. My grumpiness is not aimed at you. My question is clearly not answerable except by a few and that's fine. I've already thrown out the Yamahas as examples and the Audiomod arm as an example. It's obvious most folks just have not made this kind of direct comparison and that's okay. I've gotten enough replies here and AK to form my own thoughts.This is why I like to do search-only when it comes to gear for the most part because when it comes to asking questions the downside of the internet is the unfailing ability of most threads to somehow use the OP as just a starting point for veering off. At least when searching prior threads I can weed through what someone else tried to figure out.
I didn't want to make this any more tedious than it has become, but I think your assumptions are flawed. How can you tell opinion/preference from fact, and determine sample to sample performance variations on a 30 year old mechanical device if you have no frame of reference?Almost every post was about your initial question. Tonepub is well versed in performance of current offerings and gave good answers. I'm pretty well versed in vintage offerings, but my familiarity with new, is limited. The best vintage stuff goes for nearly the same price as when new. I have/had a couple of arms that were $1K in the '80s. Used, they go for around $900 now. That's maybe 1/3 $ of the modern equivalent, but does it perform as new and is it appropriate? Some people love old idlers but some are rumble boxes and a new idler wheel only reduces the rumble. The cult ones will be priced way outside sanity. Maybe a variety of opinions is appropriate.Good luck again to whoever is getting this. Zen is very appropriate for redirecting the way you look at things, and for change. neo
