0 Members and 1 Guest are viewing this topic. Read 9882 times.
Carlman,I recently ordered and received a Par-Metal series 20 desktop(?) case, I'd be interested as to why yours fell through? IAG has some really nice chassis's http://www.iagaudio.com/ , but they must be custom built, as I waited a good three weeks for delivery. They are very nice though, worth the wait!Also, copper fasteners are available at Mcmaster-Carr, just do a search for 'ring terminals'. They are tin plated though.... Hope it helps, Gordy
Hi Carl: Those will work if you are using 7-8 AWG wire. Do you have a crimper large enough to crimp for 7-8 AWG? Or will a bench vise do the job? d.b.
The ones I pointed out were 8awg 5/16" ring size. I had meant pulling the output wire through the case to make the ring on the outside against the spade. If I do this I will just drill a small hole next to the binding post and pull the output wire through, terminate it with the ring, slip it over the post and clamp down the spade against it with the bind post.
