DC Rail wires - should they be twisted ... or separated?
0 Members and 1 Guest are viewing this topic. Read 8483 times.
andyr
Hi,
I'd like to get your advice ... the DC leads that go from a PS to a PCB - should they be twisted (to reduce inductance) or doesn't this matter for a DC power feed?  (I know that it is the right thing to do for AC wires.)
Andy
cheap-Jack
Re: DC Rail wires - should they be twisted ... or separated?
« Reply #1 on: 22 Jan 2013, 02:20 pm »
HI.
Is it a Class A audio amp or what?
c-J
Speedskater
  • Kevin
« Reply #2 on: 22 Jan 2013, 05:30 pm »
Yes, twisted.
Something like those super high capacitance speaker cables is great.
Folsom
« Reply #3 on: 22 Jan 2013, 06:16 pm »
Why twist them? Technically it'll add a little extra heat.
AC twisting has a minor noise rejection, DC doesn't work like that.
Do whatever looks nice and isn't a struggle.
randytsuch
« Reply #4 on: 22 Jan 2013, 06:48 pm »
Twist them, heat is not a problem
Reduces noise.
Speedskater
  • Kevin
« Reply #5 on: 22 Jan 2013, 07:17 pm »
All (multi-conductor) cables should be twisted,  it reduces pick-up (and transmission) of interference.  That goes for AC power, DC power, interconnects, digital and speaker cables. The one exception is co-ax cables.
Also in DC supply cables, twisting reduces self-induction which is good. We want the DC supply source to appear as a zero Ohm impedance at both DC and to AC to as high a radio frequency as possible.
Folsom
« Reply #6 on: 22 Jan 2013, 07:24 pm »
You are going to have to explain how DC can reject noise with twisting. Considering there is no sine wave in the power section, I'm having trouble seeing it.
*Scotty*
« Reply #7 on: 22 Jan 2013, 07:31 pm »
Another vote for twist them. The DC rail is supplying power to a circuit that may operate to frequencies past 20kHz. The circuit is is limited by the AC impedance of the power supply, added inductance in the power supply wiring raises the AC impedance at high frequencies. In addition the combination of the wiring's inductance, resistance and the capacitance in the power supply can form a tank circuit that can resonate at some frequencies which will cause the power supply to ring. The best practice is to treat this aspect of the amplifier as though the amplifier was operating at RF frequencies. The more current there is in the rails the bigger the problems that may be encountered if steps are not take to keep power supply wiring short and minimize its inductance.
Scotty
andyr
« Reply #8 on: 22 Jan 2013, 07:49 pm »
Scotty
Thanks, Scotty.  The device is actually a phono stage - so drawing a max of 40ma in each channel.  But yes, it does operate waaay past 20KHz!  :)
I'm surprised there's so much disparity in the advice given but the fact that twisting will reduce inductance in the wiring seems to me to be the key argument.  :thumb:
So twist I will.  :D
Andy
jtwrace
    • TIPP YouTube Channel
« Reply #9 on: 22 Jan 2013, 07:53 pm »
Always twist
*Scotty*
« Reply #10 on: 22 Jan 2013, 08:27 pm »
There is a paucity of experience and no shortage mis-information online.
Scotty
Folsom
« Reply #11 on: 22 Jan 2013, 11:10 pm »
Scotty you are saying to twist them in order to cancel inducted AC signal?
andyr
« Reply #12 on: 22 Jan 2013, 11:25 pm »
I took his statement to mean "Twist them to reduce inductance."  (As the wiring's inductance & resistance, and the capacitance in the power supply, can combine to form a tank circuit that can resonate at some frequencies.)
Andy
Folsom
« Reply #13 on: 22 Jan 2013, 11:43 pm »
He said treat it like it operates in RF frequencies (AC).
Inductance goes up with more close proximity?
andyr
« Reply #14 on: 23 Jan 2013, 12:00 am »
I don't believe so ... capacitance goes up with proximity, inductance goes down.
Andy
Folsom
« Reply #15 on: 23 Jan 2013, 12:36 am »
Capacitance goes up by electromagnetic fields passing through material that tries to act like a dialectic.
Inductors look like this.  They can hold capacitive charges. The more cross sectional area the more inductance. But reduction in length does mean less inductance.
andyr
« Reply #16 on: 23 Jan 2013, 12:59 am »
Sure, DoS - that is an inductor!  :D
But 2 wires twisted together don't look anything like that.  If I can explain my point about inductance going down with proximity of 2 wires vs. capacitance going up, a bit further:
* with speaker cables, there can be high currents flowing.
* inductance acts as a "brake" on current - which is obviously a bad thing.
* so extremely low inductance is the best for speaker cables.
* hence, some mfrs introduced braided cables a few decades ago.
* however, the resulting high capacitance can drive certain power amps to self-destructive oscillation - so some amps need to use cables with low capacitance ...  and, hence, higher-than-ideal inductance.
Old Naim amps were like this - they needed to have a certain amount of inductance on their output terminals - which was provided by 5m of Naim NAC-5 speaker cable.
Andy
