0 Members and 1 Guest are viewing this topic. Read 18547 times.
A lot of people tell me to stay away from the Pro-Ject turntables so I am not going that route. I missed out on the SL-1200mkII so the search is still on...I'm hunting for a good deal on another one and decided to pass on the denon DP-62L. Looks nice but seems kind of finicky...
In my experience both with the Technics SL1200 and a typical MC cartridge like the Denon 103D as well as more expensive table/arm combos, even with a very good phono preamp (in the $1000+ range) you are not likely to get sound anywhere near as good as your digital system; you will definitely notice any number of unique LP distortions, though, especially inner groove and clicks/pops etc, and until you get up to line stylus type cartridges surface noise will almost certainly be audible during quiet music passages.I think you should be prepared to pay (used) upwards of $3000 for your phono system to have any hope of being a reasonable sounding alternative to your digital system.YMMV.
Actually that Denon is an excellant table and fairly priced especially since it is local and you don't have to pay for shipping and the dangers that entails when buying off of Ebay. If you check the completed listing for that table the average price not including shipping was $750 for the ones that had both arms. There were two others. One was pulled by the seller and the other only had the straight arm. If the AT cartridge on the table is good and functioning it will get you started even if it is just an AT-95e. You can deal with cartridge upgrades later. The Denon also has an electronically damped arm and auto-lift and stop, along with VTA adjustment. With the two arms you get one low mass and one medium mass for a greater choice of cartridges. It is light years ahead of tables like the Project Carbon, RP1 etc. You can likely sell this table for more than what you paid if you take care of it and decide vinyl is not for you.
The merits of this deal aside, I'm not sure it's wise to choose as a starter deck a +$500 20+ year old turntable. Also when you're getting around that $650-$750 level you start to get used tables from VPI, SOTA, etc that most would agree are serious audiophile tables with good arms, etc.I also would argue that the DL-62l is "light years" ahead of a debut carbon. For one, the tone arm is not as good, and you don't have the benefit of standard rca jacks for better cabling. Lastly, the case / plinth, while pretty, is just a fairly light & hollow box. Many owners seems to take measures to load them down to give them more mass / reduce resonants (along with swapping the arm & other upgrades). Not that the debut carbon has a super plinth, but you get my drift. I've bought a few vintage mass market tables from that era (Kenwood, Pioneer, etc) and with the exception of a good deal on a CJ Sonographe, the others have been somewhat underwhelming to tell the truth. The CJ really came into it's own because I was able to swap out the DIN cable for a better one, otherwise it would have just been ok. I spent more than half the cost of the table on that cable.Hey audiogoober - sorry if this is getting too confusing / contentious. Do you know anyone with a higher end table / preamp etc who can loan it to you to sample with you're system / room for a weekend to hear if it's worth it? I can't think of any better way to better decide if you want to jump feet first from the get go into a major investment in vinyl.
I thought my next big purchase was going to be a good DSD Transport and DSD DAC but I'm itching to give "good vinyl" a try. Another tough decision...
Unfortunately, I don't know anyone with a higher end vinyl setup that I could try in my system for a few days. Excellent idea none the less.
Where are you located?
I live in NH but cover all of NH and MA regularly on business.
A bit of apples & oranges.......if your looking for maximum value for limited budget, it seems upgrading the digital side is going to pay better dividends as this is still a constantly evolving and improving area of hi-fi, versus entering a whole new world of source & media (vinyl), which despite many active companies, is still a fairly "mature" technology where it seems that the benefits of advances is fairly modest (and often very expensive). I.e. for the former you're only changing / improving one component (the DAC), where significant improvements are still being made every couple of years, whereas with the latter you're entering into more of a complex unknown with more issues and complexities to deal with, and where the state of the art doesn't seem to advance as much.So I'd consider entering into vinyl at best as a "lateral" move and to try something else out for fun. If best bang for the buck is the primary consideration, I'd stick to improving your digital reproduction end (i.e. better DACs & digital files, maybe the power supply end, etc).
