0 Members and 1 Guest are viewing this topic. Read 8283 times.
Found this with a Google search: https://itunes.apple.com/us/app/flactunes-flac-converter/id517984121?mt=12. "It converts them into Apple's own lossless audio format. In the process, no data is lost: iTunes gets an identical, Apple-friendly version of your songs to play or load onto your iOS device."
... yes the Apple Lossless is nice, but ..... is anything truely lossless?
Yes, otherwise your computer wouldn't work.
Just referencing JND on the sensation perception side...
If you play exactly the same bits but they sound different, then you have a playback problem, not a compression problem.
So we should just do straight AIFF, no compression to solve any possible issues. Then it would never be a question.
http://www.dbpoweramp.com/dmc.htm will batch process your whole collection. Just select everything and run convert. It will ask what format to convert to.
Found this with a Google search: https://itunes.apple.com/us/app/flactunes-flac-converter/id517984121?mt=12. "It converts them into Apple's own lossless audio format. In the process, no data is lost: iTunes gets an identical, Apple-friendly version of your songs to play or load onto your iOS device."I can't vouch for it because I have not used it.
