Newest of Newbies seeking specific recs for hi-rez
0 Members and 1 Guest are viewing this topic. Read 4444 times.
jarcher
  • It Just Sounds Right
Re: Newest of Newbies seeking specific recs for hi-rez
« Reply #20 on: 18 Jan 2013, 07:15 pm »
Well, wow, thanks so much.  This is my fourth attempt, on four different forums over a span of two years, to get this type of post.  All those prior efforts failed.  I have to say that it's been very frustrating to get what now appears to be very simple information.
Your post would be a great sticky in the newbie thread or this one.
I also read the Dagogo review of HAL's MS-1, which is helpful if I go that route.
Really, many thanks.
Glad I could help.
I keep looking at dedicated music / media servers from boutique companies such as Olive, etc and keep running into problems / limitations, such as high cost, proprietary methods, upgrade-ability issues, performance issues, feature bloat, etc, etc.  And after all that, they still can't perform all the other functions a regular PC can.
I can also realize that many people want something relatively simple and don't want to devote a lot of time / effort / money to simply playing back their music - particularly coming from the relative simplicity of a turntable, cd player, etc. And for this reason DIY PC server options are perhaps a bit unrealistic.
For these reasons I still see the Mac Mini on the Apple side, and on the Window's side, the HAL's MS-1, and possibly the before mentioned CAPS V3, as the best bang for the buck.  They all have the advantage of relative simplicity, being compact, not consuming a lot of power, and being reasonably inexpensive.  I happen to like Mac's as well for the ease and stability of the operating system and the Time Machine back up function that allows simple migration to a new mac when that day comes.
For the CAPS V3, if I were considering it for myself, I'd be looking at the entry level Topanga and save my money for power supply upgrades in the future.  Even then though, I'd probably still buy HAL's MS-1 instead, or get him to make something custom for me, as it will likely cost the same or less & I think you'd get better support from him.
Best of luck!
django11
  • Canuckistani
« Reply #21 on: 18 Jan 2013, 10:39 pm »
I have a general purpose computer in my man cave so I don't see the need for a dedicated machine.  I have JRiver media on my Windows7 computer it feeds via a USB cable to an HRT Streamer II (usb dac) which feeds via rca cable to my pre amp and then to  my amp.
I now have absolutely no interest in a cd player.
JBrahms
« Reply #22 on: 19 Jan 2013, 03:12 pm »
I've seen that people run the Mac mini headless, in that case how do I download music from, say, hdtracks? I'm guessing I'd use an iPad to direct it to the mini?
jarcher
« Reply #23 on: 19 Jan 2013, 05:05 pm »
You will still need to hook it up to a monitor (or TV via its HDMI port) to see what you're doing to do stuff such as load audio files onto iTunes or whatever media management software you choose. Oh - and of course a mouse and probably keyboard as well. Once you're done with that operation, you can go back to using it " headless" as you say (with an  idevice or tablet as remote). The same would be true of pretty much of any PC, Mac or Windows.
I have my mini connected via HDMI to a TV, and use a wireless keyboard / mouse device the size of an iPhone (and it's also a basic function universal remote control to operate the TV). Reduces clutter down immensely.
http://www.amazon.com/gp/product/B006OW1J1M/ref=oh_details_o03_s00_i00
JBrahms
« Reply #24 on: 19 Jan 2013, 11:54 pm »
Okay thanks again everyone
jarcher
« Reply #25 on: 24 Jan 2013, 06:28 pm »
Looks like I may have given you incomplete information. Apparently there are ways to remote control a mac mini with an ipad beyond just controlling itunes.  See this current active thread :
http://www.audiocircle.com/index.php?topic=112446.0
JBrahms
« Reply #26 on: 24 Jan 2013, 06:49 pm »
Thanks J Archer
