0 Members and 1 Guest are viewing this topic. Read 4447 times.
If you are happy with your audio gear, a USB to SPDIF converter will do the job.Look for asynchronous USB and USB Audio Class 2 support. The latter is needed for anything > 24/96
One option is to use the PC as a source, just like a turntable or a CD player.On the PC you maintain your collection and to do so you need a media player.You type e.g. Bruckner in the search box and it shows you all you have by this composer.You select a symphony and press play.You want to get the audio from the PC to your audio gear.The USB of the Marantz is limited to 24/96 ( you can give it a try by simply hooking it up to your PC, gives you a taste where file based audio is about)The coax input of the Marantz goes up to 24/192 (wonder if the Toslinks does as the standard is 24/96). Your PC probably don’t have a coax out (SPDIF).A USB to SPDIF converter bridges the gap and allows you to play 24/192 straight into the DAC of the MarantzAn example: http://www.musicalfidelity.com/products/vSeries/v-linkii/
Sorry, wrong link.This is the right one: http://www.musicalfidelity.com/products/vSeries/v-link192/As this is all very new to you, I recommend using the USB of the Marantz.You can always upgrade later.Create a small library on your PC.Rip some CDs, maybe you have some MP3s, you might even decide to use Windows Media Player to get a taste of what this “pushing” is about.An alternative is to use a USB stick or USB HD but again you need to build a library on your PC, transfer it to the stick, connect it to the Marantz.The advantage of a PC IMHO is a better interface (including cover art) and a better support for all kind of audio formats.
All the different options can be daunting, but here goes my suggestion on the gear / connections for a first timer looking for ease of use:.....Best of luck!
The Marantz has a USB receiver limited to 24/96. This is by design, no way to change this.The Vlink192 has a USB receiver capable of 24/192.Its output is SPDIF.If it receives a 24/192 over the USB, it will transform it to 24/192 over SPDIF (coax)As your Marantz is capable of receiving 24/192 over SPDIF you circumvent the 24/96 limit of its USB input.
Well, wow, thanks so much. This is my fourth attempt, on four different forums over a span of two years, to get this type of post. All those prior efforts failed. I have to say that it's been very frustrating to get what now appears to be very simple information. Your post would be a great sticky in the newbie thread or this one.I also read the Dagogo review of HAL's MS-1, which is helpful if I go that route.Really, many thanks.
