High impedance headphone for Red Dot mk iii ?
0 Members and 1 Guest are viewing this topic. Read 1049 times.
sugbob21
« on: 17 Jan 2013, 12:22 pm »
Can anyone recomend a good over the ear headphone for  Red Dot MKiii amp ? $250.00 range mainly listen rock and occasional jazz.
django11
  • Canuckistani
Re: High impedance headphone for Red Dot mk iii ?
« Reply #1 on: 17 Jan 2013, 01:14 pm »
Little Dot?
hibuckhobby
  • On a search for audio nirvana
« Reply #2 on: 17 Jan 2013, 02:31 pm »
If you're talking about the Little Dot Mkiii, then look for a clean pair of
Sennheiser hd600's or 650's.  If you want strong bass and highs, look
at the Beyer 990, 600 ohm.  Another isssue is if you want closed or open
back cans.  For closed, the Denon 2000, the Phillips Fidelio line and the
Audio Technica line have phones in your price range.
regards,
Hibuck...
sugbob21
« Reply #3 on: 17 Jan 2013, 04:17 pm »
sorry....yes  Little Dot.  Will check out your suggestions.thx.
sugbob21
« Reply #4 on: 22 Jan 2013, 01:21 pm »
is there a significant difference  between the Beyer 990   and 880  -- 600 ohm headphones.  Price point is not too  big .
hibuckhobby
« Reply #5 on: 22 Jan 2013, 02:00 pm »
The 990 is less neutral...more bass and treble.
Hibuck...
