Compatibility of FRD format calibration files with REW software
0 Members and 1 Guest are viewing this topic. Read 1784 times.
*Scotty*
Does anyone know if the FRD files supplied by Cross Spectrum Acoustics are compatible with Room EQ Wizard (REW) software?
Before ordering the Dayton Audio UMM-6 microphone from Cross Spectrum it would be good to know if FRD format files can be used with REW for calibration.
Scotty
JohnR
Hi Scotty, yes they work fine.
*Scotty*
Muuhaa ha, muuhaa ha!
I foresee a UMM-6 from Cross Spectrum Acoustics in my future.
Maybe I will be able to get to the "bottom" of what is happening in my listening room.
Scotty
JohnR
Ah, Herb was quick off the mark... good thinking on the CSL option :thumb:
http://cross-spectrum.com/measurement/calibrated_umm6.html
