Nice lookin' switched
0 Members and 1 Guest are viewing this topic. Read 1521 times.
MattCassidy
    • http://www.claritymultimedia.com.au
« on: 24 Jun 2004, 09:52 am »
Hello again all. I would like a recommendation on a supplier for some damn nice push button switches. I will be having a brushed aluminium front plate..I had a look on altronics, jaycar and the like but they don't have a huge range.
TIA
Matt
EchiDna
« Reply #1 on: 24 Jun 2004, 11:55 am »
look for the stainless vandal resistant switches from RS components... not cheap, but can handle 10amps and 240 volts no problem.... these are about 30mm in diameter, like you see on carkparking or train ticket machines etc...
MattCassidy
« Reply #2 on: 24 Jun 2004, 09:36 pm »
Yes they are very nice, just what I was after! Thanks Echidna you sure are a helpful fellow! :wink:
EchiDna
« Reply #3 on: 26 Jun 2004, 10:50 am »
no problem ;-)
I went through the same process not that long ago, and it can be daunting but keep pluggin away, you will get there!
