Bugle DC Offset
0 Members and 1 Guest are viewing this topic. Read 1700 times.
Darterboy
Bugle DC Offset
« on: 24 Jun 2004, 03:46 am »
What is it? How do I measure it? what values are acceptable/unacceptable?
hagtech
Bugle DC Offset
« Reply #1 on: 24 Jun 2004, 05:18 am »
There can be a small dc offset at the Bugle outputs.  I forget how much, maybe up to +/-20mV.  I designed it that way on purpose to eliminate the critical output coupling cap.
You can measure by just using a DVM on the output.  Read DC voltage.  Don't apply any input.
jh :)
Darterboy
Bugle DC Offset
« Reply #2 on: 24 Jun 2004, 05:40 am »
With my meter set to DCV, and one probe touching the inner conductor and the other touching the outer conductor of the same RCA jack, I measure 5mV DC (.005 V) and 2mV DC (.002 V)on the left and right outputs repectively. Sounds like I'm cool. Thanks!
-Stott
slappomatt
Bugle DC Offset
« Reply #3 on: 11 Jul 2004, 09:19 pm »
wow! just checked this with nothing hooked up to it and powered up. i get 2.13v and 2.15v at the outputs. and .2 at both inputs. why is there voltage at the inputs? looks like i need to go back and have a look at my values and such.  :oops:
hagtech
Bugle DC Offset
« Reply #4 on: 12 Jul 2004, 06:25 am »
Slappo,
Yeah, that's because you have no negative supply.  With only a positive supply the opamps cannot drive a signal to zero.  The bias and output circuitry headroom can best do about 2V from the rail.
jh :|
