B&W ASW-850 15" powered sub
0 Members and 1 Guest are viewing this topic. Read 3275 times.
motorcitym3
« on: 14 Jan 2013, 05:36 pm »
Up for sale is barely used, maybe 200 hours, like new B&W ASW-850 in black. The ASW-850 is a 1,000-watt RMS powered sub that houses a 15-inch driver, which, according to B&W, produces more-intense, dynamic, and deeper bass than any of their previous subs. With a response rating that extends down to 18 Hz, you'd better believe it. The sub's input circuitry offers two different bass-rolloff settings that let you optimize the sub's performance for either maximum extension or maximum peak output, depending on your room, your source material, or just your personal preference. Retails over $3,000.
Located in Canton, MI 48188     Asking $1100.
Active closed-box subwoofer system
380mm (15 in) paper/Kevlar® cone long-throw
-6dB at 14Hz and 40/140Hz adjustable (EQ at A)
±3dB 18Hz -- 31/110Hz adjustable (EQ at A)
Power output: 1000W continuous
Input impedance: 33kΩ
Signal / noise: >90dB
Functions: Input level
Low-pass filter frequency
Low-pass filter bypass
Bass roll-off alignment
Auto sense on/standby
Phase switch
Inputs: Line In (RCA Phono)
Outputs: Line Out (RCA Phono)
high-passed
Link Out (RCA Phono)
Active 2nd-order, variable cut-off frequency
Active 3rd-order -6dB at 80Hz
Height: 529mm (20.8 in) not including feet
Width: 562mm (22.1 in)
Depth: 522mm (20.6 in)
including grille and controls
45kg (99 lb)
