Synergy 240 Questions
0 Members and 1 Guest are viewing this topic. Read 2276 times.
Birdbrain
« on: 11 Jan 2013, 12:23 am »
The Synergy 240 is rated at 120 wpc and for 4 ohm loads and up. What would the power output be adding the double die option, and would the amp be stable into 2 ohm loads? What would the power output be running a double die Synergy 240 with an AVA phase inverter?
Thanks, and happy new year!
avahifi
    • http://www.avahifi.com
Re: Synergy 240 Questions
« Reply #1 on: 11 Jan 2013, 11:39 am »
The double die option will add about 10 percent to the power rating as the on resistance of the mos-fet output section will be cut in half.  However the main advantage of the double die option is the improvement in thermal  and current capability, making the option useful driving low impedance and very difficult loads.
Bridge mode operation will essentially double the rated output power but only within the limits of the maximum recommended speaker fuses, which would be 5 amp quick blow for the Synergy 240.  If these fuses are too large, then your speakers will blow first, saving you the cost of replacing fuses.   :o
A much more economical way of obtaining higher power operation would be to acquire a Synergy 450 rather than two Synergy 240 amps and the AVA bridge.
Frank Van Alstine
Brett Buck
« Reply #2 on: 11 Jan 2013, 06:28 pm »
   You can get speakers anywhere. It took me decades to find some good-sounding, matched, and cryo-treated, fuses!
    Brett
« Reply #3 on: 11 Jan 2013, 08:00 pm »
    Brett
Now that's funny  :lol:
