0 Members and 1 Guest are viewing this topic. Read 6774 times.
One upgrade that will help the Debut and any future table you get is to buy/build a wall mounted shelf that attaches to the wall studs. I use a Target which may not be sold anymore but there's others out there or threads on building one.
Looks like I will start with a good shelf and I guess a recabling to allow for a long phono cable. Any suggestions on a high quality low cost cosmetically good look shelf, or should I DIY one. Are there any specific considerations to make with a DIY shelf or is simply anchoring it to the studs reducing mechanical vibrations from the floor.
