Tap-X
0 Members and 1 Guest are viewing this topic. Read 10272 times.
happyrabbit
Tap-X
« on: 9 Jan 2013, 06:27 pm »
Hi !
Do you still offer the parts to build a TAP-X ??
PRM-1 + Remote  +Slagleformer Module x2 + Internal Power PCB..  Is this possible ?
Dwight
jtwrace
    • TIPP YouTube Channel
Re: Tap-X
« Reply #1 on: 9 Jan 2013, 06:31 pm »
Yes he does.  Go to his site and you can get them all.   :thumb:
dspringham
Re: Tap-X
« Reply #2 on: 10 Jan 2013, 12:25 am »
If you don't want to go the DIY route I have a factory Tap-X available for sale.
Dave
[email protected]
jtwrace
Re: Tap-X
« Reply #3 on: 10 Jan 2013, 12:29 am »
Dave
[email protected]
That will sell in a NY minute.  Is it fully balanced?
poseidonsvoice
    • 2 channel/7 channel setup
Re: Tap-X
« Reply #4 on: 10 Jan 2013, 12:31 am »
Dave
[email protected]
PM and mail sent.
Anand.
dspringham
Re: Tap-X
« Reply #5 on: 10 Jan 2013, 01:20 am »
PM's responded to.
No, this is not balanced. It's the 6 input RCA version with Slagle Autoformer modules.
Dave
John Chapman
    • http://www.bentaudio.com
Re: Tap-X
« Reply #6 on: 26 Feb 2013, 06:07 pm »
Hello!
Sorry to miss this one - thanks guys for responding! I still do all the parts and modules to DIY up a TAP-X unit and also some OEM's use those parts inside too. Finally we will have a case option for DIY builds - I am due to get the first of those here this week.  Looking forward to that!
Thansk!
John
happyrabbit
Re: Tap-X
« Reply #7 on: 15 Mar 2013, 12:25 am »
Back in the family.... Again  :green:
WireNut
Re: Tap-X
« Reply #8 on: 6 Jul 2013, 06:52 pm »
Is the balanced Tap-X available with unbalanced inputs as well as the balanced inputs ?
jtwrace
Re: Tap-X
« Reply #9 on: 6 Jul 2013, 08:15 pm »
Yes, balanced input and outputs and RCA inputs and outputs and even switches on the fly all by itself.  I love it!
WireNut
Re: Tap-X
« Reply #10 on: 6 Jul 2013, 08:26 pm »
I'd love to see a photo of the back side   :o
Is it possible to use the unbalanced inputs but use the balanced outputs?
All my source components are unbalanced but I use two sets of balanced outputs because my active xover and amps run balanced ins.
jtwrace
Re: Tap-X
« Reply #11 on: 6 Jul 2013, 08:37 pm »
yes
jtwrace
Re: Tap-X
« Reply #12 on: 6 Jul 2013, 08:38 pm »
WireNut
Re: Tap-X
« Reply #13 on: 6 Jul 2013, 08:39 pm »
Awe man that looks sweet  :thumb:
It looks like you have 2 sets of unbalanced ins, 2 sets of balanced ins, 2 set of unbalanced and balanced outputs and a tape loop, Is that correct?
Did you build this yourself or is it factory?
jtwrace
Re: Tap-X
« Reply #14 on: 6 Jul 2013, 09:08 pm »
Yes that is correct.
You can purchase all parts through John Chapman (Bent Audio) and put it together.
happyrabbit
Re: Tap-X
« Reply #15 on: 16 Aug 2013, 08:26 pm »
More Tap-X Porn.... so lovely  so addictive  :drool:
« Last Edit: 21 Aug 2013, 09:36 pm by happyrabbit »
WireNut
Re: Tap-X
« Reply #16 on: 19 Aug 2013, 04:12 pm »
Man that looks good :o.  I bet it sounds awesome. What is that amp?  It's beautiful  :drool:
happyrabbit
Re: Tap-X
« Reply #17 on: 20 Aug 2013, 12:57 pm »
Triode Lab 2A3-S...  I have more in the tubes than the amp itself  8)    Did you sell your preamp yet ?    I am still waiting for the post @ your Tap-X !
Dwight
WireNut
Re: Tap-X
« Reply #18 on: 20 Aug 2013, 06:46 pm »
Dwight
No it did not sell but that's okay, I'm going to keep it if I can. I'll have a Tap-X someday then I'll be able to switch between a tube pre and
the Tap-X and have the best of both worlds. Your setup must sound amazing.
doctorcilantro
Re: Tap-X
« Reply #19 on: 13 Oct 2013, 04:29 am »
Can someone offer a general estimate of cost for a Tap-X with balanced to unbalanced output?
