Constant Voltage Discharge Circuit for battery PSU?
0 Members and 1 Guest are viewing this topic. Read 989 times.
Folsom
A friend of mine does recording but the battery charger for his laptop creates a lot of noise. Problem is his laptop doesn't run long enough on the regular battery (or even a bigger one) to do anything he needs to do.
I was thinking of fixing this going battery operated. Just buy a huge SLA battery, put it in a box with a charger and a selector switch... but as I understand batteries voltage will decrease some if it starts to lose too much charge. However I've seen a few PSU's for audio equipment that have a constant voltage discharge circuit. I was wondering if anyone sells one or something?
Aside from that, maybe a linear power supply that makes less noise would work. Also could build a power conditioner for him but... the $ for that is bit more than the first two options!
BPT
  • Balanced Power Technologies
Re: Constant Voltage Discharge Circuit for battery PSU?
« Reply #1 on: 9 Jan 2013, 03:56 pm »
Most laptops require 16-19VDC input from an external supply. Do the linear supply. Anything else will be higher cost and much more trouble to build and maintain. Something like this will work nicely http://www.ebay.com/itm/Precision-Variable-Adjustable-30V-5A-DC-Power-Supply-Digital-Regulated-Lab-Grade-/290647013768?pt=LH_DefaultDomain_0&hash=item43abe97988 .
Chris H.
cheap-Jack
« Reply #2 on: 9 Jan 2013, 05:03 pm »
Hi.
I'd never use any SMPS (switch-mode power supply) for any audio recordings, which will be foiled up by the RFI noise from the SMPS.
Yes, get a cheapie wallwart of the right voltage or even better, powered by batteries or rechargeable batteries.
c-J
Folsom
« Reply #3 on: 10 Jan 2013, 01:52 am »
Well I guess the problem isn't what he described.   :green:
