Avr&bit15 advice
0 Members and 1 Guest are viewing this topic. Read 723 times.
Rillo
Avr&bit15 advice
« on: 7 Jan 2013, 07:17 pm »
I have a furman spr20i voltage regulator and recently got a bryston bit 15 that I want to use on my front end equipment.what would be the best way to use both?should I plug the furman into the wall and plug the bit15 into the furman?or vice versa.I want to use voltage regulation with isolation.advice would be very helpful
tim92gts
Re: Avr&bit15 advice
« Reply #1 on: 8 Jan 2013, 05:53 pm »
Isn't that slight overkill?
Maybe plug both into the wall and connect different sets of components into each spreading the load.
magnetic.601
« Reply #2 on: 8 Jan 2013, 07:38 pm »
