0 Members and 1 Guest are viewing this topic. Read 5644 times.
my criticism of the phonitor is the seemingly "recessed" sound character of it. and i realize why it was designed this way. to combat "ear fatigue" during long, concentrated listening sessions. if you're listening clinically, you don't want the sound to be too foreward or impactful.
I think that the Phonitor should be paired ONLY with cans that are 600 ohms and nothing less. Otherwise your damping factor goes out the window and will definitely effect the lower octaves in particular as you described.
After a little more study, it does seem like the SPL amps are voiced with higher impedance phones. That makes sense, since their primary target is pro/studio use with phones that are 300 ohms and up.Sorry to dominate your thread Terry. I'm just trying to get a handle on all of this myself. I hope you get it all sorted out. Keep us posted.
