0 Members and 1 Guest are viewing this topic. Read 10555 times.
You can create a null: that's why there's a phase inverter (or phase dial) on most all amps. The crossover setting is intended to be the spot where the plots from the two drivers in question "cross over" or meet... so it should be the same for both.I think 80 is actually a THX standard.
It's not always best to cross over at all: http://www.hifizine.com/2011/06/bass-integration-guide-part-1/
80 Hz is the THX standard, so all A/V receivers will follow it. The crossover should work like any other in that the sum from both sources should add to produce a flat frequency response (the drop offs start on either side of the stated crossover frequency).The size of sound waves must be considered as it relates to phase issues. The equation is 1130 ft/second divided by the frequency in Hertz (Hz). Example: an 80 Hz sound wave is 1130 / 80 = 14.1 feet long. So at that length phase issues are quite secondary. Higher frequencies are shorter, lower frequencies are longer.It is generally agreed that below 100 Hz, the direction of sound is not discernible, so it's OK to combine channels. (Unfortunately most have taken that to mean that one sub/system or room is also OK, which it definitely isn't for obtaining a flat frequency response, as referenced in JohnR's link. Considering bass sound waves being 20 - 60 feet long and equating them to large waves in a bath tub you can see how the waves will easily add or cancel out, creating huge variations in the space.)
Or just dump those nasty crossovers and buy truly full range single driver speakers (rare).Crossovers are, at best, necessary evils. They reduce efficiency, introduce phase and intermodulation distortions, and obscure the amp from "seeing" the simple/pure load from a single driver. The best crossovers are found in active designs (one amp dedicated to each driver) where they only handling low level signals and so can be more sophisticated and made of premium parts.The stated crossover point is where the signals cross in the above diagram.
Thanks for the article.Based on the article, it seems that the xover point just hapeend at much higher point. In many case, the abudant overlap doesnt work well in home invironment or does it? And that would be assuming that the sub and main are at the same phase but this is probably the bigger issue with integrating sub because sub it is always in phase lag.
The overlap can work well. The graph I was thinking about is actually in part 3 - http://www.hifizine.com/2012/06/bass-integration-guide-part-3/ - Figure 17. The idea is that by increasing the effective number of sources you may be able to smooth the response in the overlap region. However, the only way to know is to measure it.There are tradeoffs - depending on the mains, they may be better off being highpassed.I find that the simplest way to do the subwoofer crossover is to use delay to align the impulse responses of the subs and mains and EQ to extend the response past the crossover point. Then use a symmetric crossover filter. However if the mains are rolling off at the same frequency then the sub lowpass will (may) need to be steeper. And if you have a lot of room interaction around there then adjusting the crossover points/slopes can be used to smooth things out.Hope this helps, I'm not quite sure of what your question is
Absolutely High Pass the mains....Jim
Yet, in my case, i have the front cross at 80HZ while my sub are rolling at 50HZ. I find this setting to have much better bass definition and extension.
No, not necessarily...I suspect it's probably related to the delay/phase shift between your subs and the mains. And a crossover filter has its own phase shift, so changing the frequency can make changes to the response that are more dramatic than just the amplitude slope would suggest. But, it's the final response that counts
I used to crossover the mains, now I never do. More bass spread throughout the room can be good. The only time it's bad is if the bass for blurays/DVDs gets sent to mains, but that's not the case in my system. I have two subs I've attempted to place in "random" positions (as random as I could put them).
Jerry,i understand that the xover point should be the same for both the high pass and low pass, after all this is where the high meet the low. What im confused is, if the avr is stating 80HZ xover, that could be either the roll of point or xover point or both at the same time. In the case of both at the same time, the xover point would be at 0db. But in case if that is the roll off point, and in the case where the sub low pass is set to 60-50HZroll of, the crossover point would be at different and at different db. It is essentially blending both(mains+sub) at a lower db xover point.Does that make sense? If one is xover at 80HZ at 0db that would create too much ovelap at 80hz.
Ricardjoa, the way crossovers work they should sum to unity at the crossover point (well, not always quite, not all crossover curves are maximally flat, but that's the general idea). In other words, when you set your crossover to 80 Hz, neither the signal to the sub nor the mains are flat at 80 Hz; rather, each is rolled off at 80 Hz so the summed response is flat.
