Best mid for RAAL 140-15D with passive crossover
0 Members and 1 Guest are viewing this topic. Read 3349 times.
this_is_vv
« on: 4 Jan 2013, 12:05 am »
So i got my RAAL 140-15D  and have been in search for the mid that can keep up with it...and after reading various commercial and DIY i have come up to following drivers...i am keeping these as open baffle more like philharmonic speaker...
Accuton Mids
Scan Speak 18W
Neo 10
.i currently have H-frame AE IB15 from 150hz and below///using active crossover...and i want to pass 150 and up to RAAL and Mid combination....
i want to crossed around 3.5Khhz onwards to RAAL.....any input any suggestions.....4
V
spldrag
Re: Best mid for RAAL 140-15D with passive crossover
« Reply #1 on: 4 Jan 2013, 12:53 am »
A Beyma 10mi100 midrange has the efficiency to keep up with it
cab
« Reply #2 on: 4 Jan 2013, 01:00 am »
Neo 8 or Neo 10....
JoshK
« Reply #3 on: 4 Jan 2013, 03:06 am »
150hz-3.5khz is a tough requirement.   Few really good mids go as high as 3.5khz.  In truth if you cross there you want a mid that is smooth till 5khz I'd think.   Don't know many, certainly none that do 150hz well also.
You sure you need to cross the RAAL that high?
this_is_vv
« Reply #4 on: 4 Jan 2013, 03:49 am »
Nope i can cross i guess from 1.8khz to upwards...but people recommened around 3.5....i think even 2.5 - 3Khz would be great..i think only neo10 so far is very smooth..any suggesstions??
V
richidoo
« Reply #5 on: 4 Jan 2013, 04:31 am »
Selah Mejor uses this tweeter, with a Scan 7" aluminum illuminator, crossed with DEQX.  Extremely transparent sound, perfect integration, perfect tone. The Illuminator motor is very advanced, this is an awesome mid. Rick doesn't tell his secrets so I don't know the Fc, but I bet it is lower than 3500. I would recommend crossing as low as the ribbon mfg safely recommends, 4th order, closer to 2k so that the mid's dispersion better matches the ribbon off axis. Use a cap on it to filter out DC.
this_is_vv
« Reply #6 on: 4 Jan 2013, 05:07 am »
i think you are talking about these...
http://www.madisoundspeakerstore.com/scanspeak-woofers-6-7/scanspeak-illuminator-18wu/4747t-00-7-aluminum-cone-woofer-4-ohm/
even these also uses same speaker as per 6moons...
http://www.6moons.com/audioreviews/bogdan/2.html
The drivers employed are the same amorphous C-core version of the Raal 140-15D tweeter as used in the Petra and the Scanspeak Revelator 18W/8531G
this_is_vv
« Reply #7 on: 6 Jan 2013, 05:24 am »
Bump^
