OS-CON CAPS
0 Members and 1 Guest are viewing this topic. Read 1956 times.
navi
OS-CON CAPS
« on: 22 Jun 2004, 01:11 pm »
Does anyone know where I can get OS-CON caps in australia?
Ivan
ginger
OS-CONs in OZ
« Reply #1 on: 27 Jul 2004, 03:51 am »
OS-CON also listed in some catalogues as "Solid Aluminium"
Good source is Rarefaction in Melborne (search the web) - limited range BUT excelent prices.
Sanyo SA Series and SH Series is available thru' Radiospares.
Full Sanyo range available thru' Farnell
Farnell appear to be cheaper than R.S.
CAUTION: OS-CONS are great for digital supply rail bypassing and other critical applications BUT they have two bad habits
1) They have NO overvoltage tolerance - exceed their voltage rating even momentarily and they WILL blow.
2) They blow Short Circuit.
I used to use them for cathode bypasses on the EL84 Output Valves of my little valve amp untill about the 4th time I spotted valve anodes glowing orange due to blown OS-CONs shorting out the cathode bias. I now use Blackgate Standards instead.
Ginger (Electronic Design Engineer)
ASi_TEK
  • NO LIMITS!!!
    • www.asi-tek.com
OS-CON CAPS
« Reply #2 on: 27 Jul 2004, 03:59 am »
Try the Rubycon ZA/ZL series sometime, (if you can find them down under). They are lower in impedance and have a higher ripple current, I believe.  I use them in bypass and decoupling applications and they are awesome! I haven't had one blow yet. Thanks
