Like New GR Research N2X Set - SF Bay Pickup - $450
0 Members and 1 Guest are viewing this topic. Read 1178 times.
devinkato
SOLD TO pwag - Thank you very much, please enjoy them.
I have a set of GR Research N2X monitors for sale.
http://gr-research.com/n2x.aspx
I'm selling them for less than the price of the components (makes me sad).  They've been installed and used for less than a year.  They are beautiful sounding.  Very balanced and non-exaggerated.  Typical Danny Richie creation that is worth much more than they're sold for.  I didn't use these nearly as much as I would have liked to, as they went into a listening room that I wasn't able to use very much over the past year.  I've recently moved and have done away with having a listening room, and am going to be using the living room (needing floorstanders) for my new listening location.
I want these to go to a good home, as I put many hours into building them.  I would like to sell to a local buyer (SF bay area) and avoid risking shipping them.  They're in perfect working order and can be tested for functionality for buyers.  I'm unable to set them up in a specific listening environment (no space), so no critical listening demos available.
Build Details
- They're built according to spec, using 3/4th inch MDF all around.  Vertical edges are rounded over with a 3/4th inch bit, and the tops are chamfered with a 1/2 inch.
- Edges were sealed and filled using Rage Xtreme Gold filler.
- Wood was sealed using a shellac primer, then sanded with 400 grit sandpaper.
- Cabinets were then painted using a filler primer, then wetsanded with 600 grit sandpaper.
- They were then painted using automotive metallic acrylic enamel paint, in anthracite grey.  This was mixed and shot from a HVLP gun for a beautiful finish.   I have included a closeup of the paint below.  The metallic flakes look great and I've gotten many positive comments by people in person about the paint.
- I painted the tweeter faces using paint that matches the woofer basket.  This gets rid of the BG logo (looks cleaner)
« Last Edit: 4 Jan 2013, 12:52 am by devinkato »
pwag
Re: Like New GR Research N2X Set - SF Bay Pickup - $450
« Reply #1 on: 3 Jan 2013, 02:07 am »
PM sent
devinkato
« Reply #2 on: 4 Jan 2013, 12:51 am »
