0 Members and 1 Guest are viewing this topic. Read 11536 times.
What about maybe stretching your budget and get the Salk recommended amp that he uses as shows?See here http://www.audiocircle.com/index.php?topic=112380.0
I'd go with the Jolida; more power and the tubes are still pretty fresh. Plus that brand is pretty solid IMO.
How about the Cary SLi-80 , came close to getting one myself.
I have heard the Rogue stuff and did like it. But I also tested the Line Magnetic Audio 216IA at Don Better Audio. I actually feel in love with this ptp wired model. It sounded better than the Rogue to me, so I bought it! Never heard the Jolida stuff, but I think AudioKarma.org has a following of this brand under Grant Audio forum.http://donbetteraudio.com/products/amplifiers/
they look nice indeed.. but forgetting price for a moment, the power output seems low..?15 watts per channel in triode, 32 watts per channel in ultra linear.Tom
I ran the SongTowers with a 40 watt Bob Latino ST70 for a couple of years. It was really a sweet combination that never sounded stressed at reasonable SPL's.( mid 80's with mid to high 90 peaks) TAS made very positive comments on the SongTower/ VA Ultravalve combo.( 35 watts? ) I suspect the 32 watt rating just indicates the tubes are being run a tad more conservatively. Remember that tube amps sound much stronger and remain more composed than solid state amps of equal or even much higher power ratings. Plus you have a very nice Rythmik sub to help in the bass..... perhaps the only area these amps may come up a tad short.
I love Rogue stuff. I have three of their products in my system. However, I think I'd avoid the Mk I version of the Tempest. It has a reputation of running the tubes fairly hard, resulting in tube replacement more often. And tubes ain't cheap! You could probably still find a Mk II, which has a totally redesigned circuit and sounds amazing, within your price range. If you could actually find a Mk II I'd recommend it over the Jolida as it is more versatile; you can roll in any normal octal - even the KT120, it has triode/ultra switching, has headphone and phono capability (phono board available from Rogue), uses 1/2 the tubes for nearly the same amount of power (the Mk II is 90 watts/channel in Ultralinear - and no fan in Mk II). It's also designed and built here in the US by good folk. If you wanted, you could have it upgraded to Mk III status and even do the Super Magnum upgrade for even better transparency if desired. My 2 cents.
