Putting the convenience factor aside for a moment, is it feasible to run any line-level source into this one input with good results?
I’m wondering whether I should leave the volume pots in the power amp and build an external switchbox, or remove the volume pots from the amp, and build an external switcher/volume box, ie . “passive” preamp!
Hi BenIt depends on the quality of the pots in the amp... my inclination would be to either modify the amp to add another pair of inputs and a switch, or bypass the internal pots and use an external preamp of whichever kind (active or passive) you prefer. But, the most sensible option if you're happy with the sound with a source plugged straight into the amp, would be to just build an external switchbox.BTW what amp is it?
Hi, this might be a well worn newbie question, but here goes!What is the function of a preamp, besides input selection and volume/tone/etc controls?
Reason I ask is that I’ve seen a lot of tube power amps around lately, that feature a volume control so as to enable the amp to be used as a quasi-integrated amp if you only have one source, presumably a cd player. Is this really a good idea? Putting the convenience factor aside for a moment, is it feasible to run any line-level source into this one inp ...
If the output level and impedance of the source component match well with the amplifier, and the amp's volume control is good, yes, this can be a very nice configuration. Whenever you can eliminate connections and circuitry it is generally considered a 'good thing'. The problem of course is that very few people actually only have 1 source component. Most have at least 2, many have 3, and some have 4 or more. Many people also want or need a tape loop. Tape loops are a common feature on preamps and integrateds, but never found on power amps.
thanks Dan. So if I'm happy with the amount of gain I get just from my poweramp (with built-in attenuater), all I need is a device for source switching, tape loop if required, and to "adjust" the impedence. What I need to know is how necessary is this impedence matching function.
Don't manufacturers adhere to some kind of standards so their products' impedences are in the same ballpark? When is an impedence mismatch likely to show itself with professionally designed products and what ill effects can there b ...
