Salk/Rythmik 12" sub specs?
0 Members and 1 Guest are viewing this topic. Read 3033 times.
rohrej
« on: 1 Jan 2013, 04:01 am »
Just wondering if anybody could tell me the dimensions on their Salk/Rythmik 12" sub?
I'm trying to figure out if I can squeeze these in to my room, or if I should stick with the standard Rythmik F12.
If anybody knows how it measures compared to the standard sub I'd also be interested in that info.
jsalk
Re: Salk/Rythmik 12" sub specs?
« Reply #1 on: 1 Jan 2013, 01:52 pm »
What size do you need?  As long as we maintain the proper internal cabinet volume and the driver fits in a resulting cabinet face, we can basically build a custom version to fit your needs.
- Jim
rohrej
« Reply #2 on: 1 Jan 2013, 08:44 pm »
I'd like to stay within a 15x15" footprint.  What would the height end up being?
jsalk
« Reply #3 on: 2 Jan 2013, 06:04 pm »
About 23" tall.
- Jim
rohrej
« Reply #4 on: 2 Jan 2013, 09:09 pm »
What is the performance gain from the additional volume, compared to Rythmik's 15.57x15.75x17" F12 enclosure?
rick240
« Reply #5 on: 2 Feb 2015, 12:58 am »
I know this is a bump, but I was wanting some more discussion on a couple of Salk/Rythmik questions - as I am getting the plans going for the 5.2 and 2.1 for my new house (planning to break ground in March/April).
I assume the answer is more volume is needed for more bracing.
For the Rythmik 12, Jim - do you have a standard size? Or is everyone pretty much custom?
Also wondering about doing a build with the dual 8" package (using http://www.rythmikaudio.com/DS800ci.html). As I understand these need about 1.7cf volume. Are these the woofers in the Exotica?
SCompRacer
« Reply #6 on: 2 Feb 2015, 05:09 am »
I inquired about this a week or so ago. Per Jim "our "standard" 12" Rythmik build is 16" x 15" x 201/2" tall."
