0 Members and 1 Guest are viewing this topic. Read 2483 times.
Maybe jriver and ???. It is a windows 7 pc.
J. River Media Center 18 and JRemote for iPad. Besides being able to specify an ouput different from the Windows default sound driver with multiple WASAPI modes, you can set each sample rate as bit perfect or to upsample or downsample to perfectly match any DAC's capabilities. Steve
If the HTPC goes to my AVR, which has 192K/24 Bit DACs, wouldn't I want to just pass the unmodified digital file thru to the AVR?
In your case, yes if your AVR can process all bit rates. Some receivers only go to 96KHz, while there are some that do go to up 192KHz but may not be able to process every resolution like 88.2KHz or 176.4KHz.Steve
Any suggestions for small enclosure PC hardware to be the HTPC?
It handles everything I've purchased from hdtracks, including 88.2 and I think 192...I prefer getting a good AVR, using its' Dacs, and then being able to use Audyssey room corection.I'll take a good look at jriver and jremote. It sounds like what I'm looking for. Thanks.Any suggestions for small enclosure PC hardware to be the HTPC?Bob
