$500 2 or 2.1 system
0 Members and 1 Guest are viewing this topic. Read 1483 times.
pjchappy
« on: 31 Dec 2012, 02:56 am »
My parents are looking for a small stereo system to go with the living room TV.  Not looking for the ultimate in fidelity.  Basically, something that will be better than the speakers on the flat screen and for occasional music.  Pretty small speakers are wanted, so a 2.1 system may be what is needed.
The budget is $500 for the speakers and receiver (ideally, even a little lower).  Any suggestions?
Thank you,
Paul
medium jim
Re: $500 2 or 2.1 system
« Reply #1 on: 31 Dec 2012, 03:23 am »
PJ:
I have a Yamaha RX-V2200 that is about 10 years old, I haven't used it in about 4 years...they sound great for what they are and listed over 2K back in 2002 when they were first out.  They can be found on eBay for around $100, which is a great price.  Find a pair of Dynaco A25's for under $200.00 and then you have around $100 to find a decent small sub...the total is $400, which leaves room for shipping....
Another thought is hitting you local Goodwills and Salvation Army stores as they get a lot of decent stereo gear right after Christmas...I woundn't count on finding decent speakers there, but many decent receivers in the mid-fi range.
Good luck,
Jim
mannye
    • http://home.bellsouth.net/personalpages/scripts/community.dll?ep=16&groupid=23441&ck=&userid=1657900
« Reply #2 on: 31 Dec 2012, 03:58 am »
I think you should take a look at "Home Theater in a Box" setups.  They offer a quick and complete solution.  Here's a link fro you to read...  Hope that helps!
http://www.hometheaterforum.com/t/298486/best-htib-for-around-500-i-know-they-are-usually-junk-please-help
srb
« Reply #3 on: 31 Dec 2012, 05:24 am »
Dynaco A25s are 20" H X 11.5" W X 10" D !
Kanto Yumi powered loudspeakers + Pioneer SW-8 Subwoofer
Speakers are 10.7" H X 6.9" W X 8.1" D, remote controlled, 2 - optical inputs, 2 - analog inputs, Bluetooth for when you come over with your iPhone/iPod/iPad or other Bluetooth portable and subwoofer out.  No room for separate receiver needed.
$470 shipped for both.
