Another Apple Newbie
randytsuch
« on: 30 Dec 2012, 06:40 pm »
For Christmas, my daughter got a new Macbook, and I got her 4 year old hand me down.
It is a 2.4 GHz Core 2 Duo with 2GB RAM and a 250 GB hard drive currently running OS X 10.6.8 (Snow Leopard).
I am thinking of increasing RAM to 4 GB, and upgrading the OS to Mountain Lion, since both are fairly cheap upgrades.
I have been trying different music players, COG, Fidelia, Vox, Amarra and of course iTunes.
Right now, I like Vox and Fidelia best.
I am hooking it up though USB to a Pupdac
http://www.head-fi.org/t/385013/my-dac-design-pup1-dac
I have a USB isolator using a linear voltage reg to power the pupdac.
Pupdac is directly driving either TDK BA200 IEMs or the JVC HA-S400 http://www.audiocircle.com/index.php?topic=112485.0
I compared the Macbook using VOX and Fidelia this morning to my Dell Latitude using Foobar, and liked the Macbook better, Dell seemed a little veiled in the comparison.
I am also planning to buy a IFI Audio iDAC, and see how I like that
Any other suggestions for things to try?
Randy
liddown
Re: Another Apple Newbie
« Reply #1 on: 30 Dec 2012, 06:58 pm »
I would recommend that for player software you give both Pure Music and Audivana+ a try....
randytsuch
« Reply #2 on: 1 Jan 2013, 04:48 pm »
When I get my new iDAC I was planning to do those trials, I don't want to use up my trial period now.
BTW, I updated the OS to mountain lion but I haven't tried to see if I can tell a difference.
Randy
