FS: AudioPrism Noise Sniffer Power-Line Analyzer (SOLD)
0 Members and 1 Guest are viewing this topic. Read 964 times.
tbabb
Used but works just fine. Essential if you want to use the AudioPrism shunt devices or similar. $90 + shipping
..Noise Sniffer ...Power-Line Analyser
Electrical power comes from a variety of sources through an extensive and far reaching power grid. When it arrives at the service panel, it will most likely be connected in parallel with other service panels throughout the neighborhood. Since these panels are interconnected, and all electrical devices on the line present mild to difficult loads, harmonic distortion or noise is created that can interfere with sensitive audio and video equipment. Prior to the introduction of the ACFX ™ Power-Line Filter and the Quietline ™ Noise Reduction System in 1993, AudioPrism developed sophisticated techniques and instrumentation to look at and listen to noise. Many of these tools were purpose designed and quite specific to the sport of "noise hunting."
Unfortunately, most laboratory instruments are far too sophisticated and expensive to use in the field and create data that is not always easy to interpret. Realizing that there was a need for a small, easy to use device that could find the source of noise on a power line, AudioPrism created a product as effective as their laboratory equipment, only much more affordable and significantly easier to use.
The Noise Sniffer ™ is a unique device developed to detect noise traveling on the power line. Using an internal circuit that converts line noise to a signal that will drive a small speaker, the Noise Sniffer ™ makes it possible to "listen" to the EMI and RFI noise that is almost always present on power lines.
By plugging the Noise Sniffer ™ into an electrical outlet and listening, you will be able to tell if the circuit or outlet you are testing has a noise problem. By evaluating each circuit independently, you will know if localized treatment with a product as the Quietline ™ Noise Reduction System is appropriate, or if filtration from an ACFX ™ Power-Line Filter or Power Foundation ™ is necessary.
There is no simpler method available to detect and eliminate noise than with the Noise Sniffer ™ and AudioPrism's power distribution and filtration systems. - Detects EMI & RFI on household power circuits
- Directs your attention to problem circuits that may require power filtering.
- Plugging it into the output of a power line filter outlet will allow you to judge the filtering performance.
- Will detect any changes made to a circuit from house-hold appliances or heavy equipment that may be re-flecting noise back into the power line.
My ebay ID = timbabb http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback2&userid=timbabb   Audiogon http://app.audiogon.com/users/tbabb/feedbacks
http://www.audioprism.com/noisesniffer.html
« Last Edit: 1 Jan 2013, 06:10 pm by tbabb »
fz1jmp
Re: FS: AudioPrism Noise Sniffer Power-Line Analyzer
« Reply #1 on: 31 Dec 2012, 02:45 pm »
PM sent with question
