Santa brought me a new toy for my Amadeus
0 Members and 1 Guest are viewing this topic. Read 3136 times.
threadkiller
« on: 28 Dec 2012, 03:31 am »
I've been using the $100 Auditorium mat for some time- very worth while upgrade. It's been talked about on here before.  You can get it at most WTL dealers.
I've been curious to hear the newer, thicker mat by Auditorium, and Santa baby came thru.  Nice thing for many of you without a good dealer for table setup is that this mat is about the same thickness as the stock foam mat, so an easy swap for those of you setup challenged.
Anyway, it's an improvement over even the $100 version, so I'm very very pleased with the results I'm hearing.  More see-thru-ness, cleaner bass, and more of that Sam Tellig there there.
Not sure the price, it may have been mentioned on an earlier thread, I think a couple hundred for this one.
Seek it out, it's worth it.
Chas
I'll upload a photo when I get my laptop out.
threadkiller
Re: Santa brought me a new toy for my Amadeus
« Reply #1 on: 28 Dec 2012, 07:44 pm »
Erocka2000
« Reply #2 on: 28 Dec 2012, 08:03 pm »
Very nice. I've been curious about the Hommage mat. Can you describe the feel of it? Is it rigid or soft like the original A23 mat?
threadkiller
« Reply #3 on: 28 Dec 2012, 08:08 pm »
It's fairly rigid, wool felty feel, sort of like a grandfathers old wool hat.
And, seems immune to static cling, which some of you have issues with.
Not sure what hapoened to my captions... I am challenged, I tell you.
Wasatch
« Reply #4 on: 29 Dec 2012, 01:45 am »
Very Nice!
mgsboedmisodpc2
« Reply #5 on: 29 Dec 2012, 07:56 pm »
Would the Auditorium mat work work well with the square motor well tempered classic?
threadkiller
« Reply #6 on: 29 Dec 2012, 07:58 pm »
No, absolutely not...
Keep the classic bare..
