FS Eastern Electric Minimax pre-amplifier with Tom Tutay upgrades, NOS
0 Members and 1 Guest are viewing this topic. Read 3566 times.
sonicxtc
Eastern Electric Minimax PRE AMPLIFER.
Excellent condition.
Pet free, child free, smoke free, music filled room.
A few years after their initial launch, Bill at Morningstar upgraded all the stock units to the consistent
praise of all listeners. In addition, my unit was tweaked by Tom Tutay (one of the finest tube modders out there and a true blue gentleman). The goal was to provide a greater range in the volume control
and while he was at it he provided a means to further reduce the all ready low noise floor. The gain was reduced sligthtly and that has proved beneficial with the associated amplifiers I utilized. This should prove helpful with higher efficiency speakers. My range on the volume dial went from 8 to 9:30 to around 9 to 2:30. Much easier to dial in the precise volume desired. The overall sound quality improved, too.
Both goals were readily achieved. BTW, if you ever need tube mods, I give Tom my strongest recommendation.
Someone PMed about the mods. Long story short, while Tom had the unit open, I thought it wise to ask what else can be done to improve upon it. He said with these final mods, he'd taken the minimax to the max. We'd reach any sane law of diminishing returns. The only means to improve upon it would require a much larger chassis and an ultra high end parts swap.
I purchased a few NOS tubes for the unit, including the king of rectifiers, the Tungsol. available option. I will include one NOS 6x4 rectifier tube.
FWIW, I tend to do a lot of research before purchasing any gear. I have several pages of information from a variety of sources singing the praises of this pre-amp as being a genuine giant killer, often besting $4,000 units. Happy to share that information with you upon request.
These are rarely on the used market and I suspect that's because most owners are ecstatic with them.
I'm considering a new direction, and that is my only reason for selling this. I hope I'm making the right choice.
Feel free to ask questions.
I have perfect feedback on Audiogon and will share all that on request.
Can provide pics when I return home.
For those who like to tube roll, this unit provides many options. There are entire threads on tube rolling with this unit.
Excellent condition. All original factory modifications included.
Original box, manual, etc.
Additional tubes available.
$800. $790.
Thank you.
Some review excerpts.
From that perspective, the MiniMax trio will leave you wanting for nothing. To be honest, with a budget of $2,700 for amplification separates plus a digital front-end with headphone jack, comprehensive remote, HDCD and digital out; with this level of fit'n'finsh and sonics - I wouldn't know where else to go. I should add that prolonged exposure to the rarefied airs of statement-level products -- whether one likes it or not -- tends to create a certain threshold below which one's attention quickly drifts and writes off components that others less jaded, over-stimulated or expectant could happily live with forever after. Let's be clear that even being used to some $85,000+ worth of designer gear did not elicit sentiments of compromise from the company of these Eastern Electric minis. Outside of the soundstage which is truly gargantuan, aspects like dynamics and ultimate transparency are simply scaled back a bit as you'd expect. More importantly, the peach, though smaller, still tastes every bit a peach.
That's the most important accomplishment of affordable anythings - to spread their compromises around in such an even-handed fashion that you don't notice them. Areas of relative compromise here involve incisiveness, rise times, noise floor and ultra-dynamic voltage swings. But the areas of tone and timbre, richness and depth, flow and involvement step out of this relativity and stand proudly on their own against far more expensive gear. This simply means that if the latter qualities are your priority, there really is no good reason to spend more. None. Should you fancy the former aspects more, you can get closer to your dreams elsewhere but chances are very good that you'll end up with less of the other qualities in turn. This should give you a good idea whether MiniMax squared to the third power is good for you or not. Today's award is for the system as a whole which clearly benefits from additive magic in how the components gel with each other. Going solo, it's the preamp that deserves an award - and we've already taken care of that in the past when we first came across it.
above by Srajan at 6 moons
I own one. Ive ran several audio research, Audible illusions M3a's ect. this little preamp sounds as good as unit 3-4 times its price. I suggest give it a try. Unit responds Very well to rolling and because of its design, matched pairs of tubes are not needed. Its fairly quiet but not the best. I have $22,000 speakers and im not looking to upgrade the preamp at this time
Re: the original upgrade....
"The new upgraded MiniMax has a bigger power supply,  and the Electrolitics in the output have been changed to polyproplene. There were some other internal tweeks performed which has lowered the output impedence to about 700 ohms. Also the gain has been lowered from 20db to 18db which is not a lot but it lets you use a little more of the volume control."
This quote is from Bill at Morningstar regarding the upgraded he did to all units. Mine was taken further up audio scale by Tom Tutay.
« Last Edit: 2 Feb 2013, 07:42 pm by sonicxtc »
mytubes211
  • Please no BS !!!
Re: Eastern Electric Minimax pre-amplifier with upgrades
« Reply #1 on: 8 Jan 2013, 08:04 pm »
Hi, can you tel me what amps you use with this Preamp. Also, can you send me any pictures and sound specification in your words?
Thanks Ritchie
sonicxtc
I've had a few inquiries and a ready buyer, yet still available.
