0 Members and 1 Guest are viewing this topic. Read 3425 times.
I think most audio users would advise against putting a regular hard drive in the enclosure. It's better to us externals in a RAID configuration for music storage.
I don't think I would use RAID for music storage.
So a small SSD for the OS and USB or Firewire external drive. Thinking the Firewire would be a better choice for the external?
My stripped down Mini is now in a similar place to Bob Lloyd's. Following the advice of Mark, of ItemAudio, this is what has been done:Small SSDSOtM SATA filterOptical drive removedAll Wireless/Bluetooth antennae removedBluetooth board removedFan removedLarge heat-sink with fins mounted to CPU (Mini now recased)(GPU has standard heatsink only, Mini is used headlessly)According to the readout on my Belkin PF40 the Mini draws almost no current. So far, using a VNC programme and SMC fan controller, the operating temp hovers around 33C. If I connect the monitor and mouse to research something on the web for a while, the temp sticks at 42C. I'm pretty happy with these results.I am even happier that each modification (I did it in stages) has bought about very recognisable changes, with a most definite cumulative improvement (There was one stage where I thought I had a retrograde step, but some experimentation and the completion of the next stage showed it did add to the overall improvements). Given the above I have made arrangements to buy Bob's SR3, once Paul makes Bob's SR5. Having laid the groundwork, I am excited to see what the SR3 brings to the system.Thank you Bob, and Paul, for introducing a new and productive train of thought that has improved my system significantly.
All the above may seem a bit of an odyssey, and will say it's a waste of time modifying any computer for audio use, and they put up perfectly convincing reasons for this to be so. I haven't had cause to agree, but I will say that even a standard Mini, with Audirvana+ and a decent USB DAC can significantly outperform most CD players/transports up to a certain (pretty high) price point. So it's worth starting with whatever Mini you want, and changing stuff bit by bit (see what I did there?).
I'm looking at building a starter Mini system. The 2009 Mini seems like a good deal on the used market. I figure max out the ram. OWC SSD drive for system OS and an external Firewire drive for media. Or would it be OK to use the OWC Data Doubler kit with a SSD drive and regular drive internally? I've been using Bitperfect and Pure Music. I would control it with iPad or iPhone. With a HDMI adapter I should be able to hook the Mini up to a TV for initial set-up right? Is the 2009 a good choice or is there a better year?
