0 Members and 1 Guest are viewing this topic. Read 4808 times.
The coarse steps of almost all attenuators make seamless pots preferred by some.
Decent dual-gang Alpha potentiometers (linear or audio taper) are still available from places like Mouser. $2.73 each...that's value. http://www.mouser.com/catalog/catalogusd/645/824.pdfIf you're restoring an old piece of gear, making it work and look fairly authentic is probably more important than any subjective audio quality, eh? Cheers,Dave.
A potentiometer with variable resistance? Oh my goodness.Since Mark is working on mono preamps it makes little difference with regard to section tracking, does it not?Cheers,Dave.
That methods works pretty well with the exception that sometimes the resistance varies on the pot.
That is really true of any potentiometer and is all dependent on tolerances - you are at the manufacturers mercy. Still, room effects swamp out the small differences in my honest opinion. You can have much better tolerances with a stepped attenuator but at a price. It all depends on your level of audiophile neurosis I've got plenty myself, judging by my builds Best,Anand.
