0 Members and 1 Guest are viewing this topic. Read 7555 times.
Is it likely that I would need a preamp after the PLL to compensate for the insertion loss?
...Is it likely that I would need a preamp after the PLL to compensate for the insertion loss?...Cheers
Many thanks,I take the point that it makes sense to get the placement right before messing with the active crossovers. I have read that in general the SQ might be better using an analog approach. Its clear that there are people here who could design the PLL circuit and if so this would be my preferred approach. I dont anticpiate changing the setup much once i am happy. Is the necessary information available to do this for the 1.6QR? Is it likely that I would need a preamp after the PLL to compensate for the insertion loss?Any comment on the typical price range for 1.6 Maggies?Cheers
What is the concensus opinion on the miniDSP?cheersBeardy
I did go the minidsp route with my magnepan 1.6's. You can read about it here:http://db.audioasylum.com/mhtml/m.html?forum=mug&n=184970&Although at present I am in the design phase with significant help from Davey to implement a PLLXO (passive line level crossover) or ALLXO (active line level crossover). I am happy with the sound of the minidsp, but I just want to try the experience of tweaking them with the PLLXO approach.
