Time to Turbo charge!
0 Members and 1 Guest are viewing this topic. Read 1453 times.
SoCalWJS
« on: 20 Dec 2012, 02:49 am »
Finally got the Turbo kit from Sandbagger! Not quite sure when the install will begin, but should be straight forward. Haven't taken this MFW-15 apart since I first got it (it arrived DOA, so there was a bit of work getting it running)
Had the hum issue which was mostly alleviated with a cheater plug, but I've been nervous about the amp the whole time. Been hoping for this for quite awhile now. This should take care of my bass needs for a long time.
Wonder if there's any other work I should do while I have it apart  :scratch:
Think there'll be any difference?  :green:
SoCalWJS
Re: Time to Turbo charge!
« Reply #1 on: 20 Dec 2012, 07:21 pm »
Got the old one out - took a bit of elbow grease to get the plate amp out, but once Kevin told me the trick, it was easy.
Hope I don't get them mixed up.......
