Luxman D-06 CD player
0 Members and 1 Guest are viewing this topic. Read 1596 times.
maxboy00
« on: 18 Dec 2012, 08:56 pm »
I have the above CD player, it is about 2.5 y/o and I did purchase it used from Agon, it is a great player, but lately it has a difficult time loading a CD to play, the tray keeps opening/closing with a CD loaded, but fails to read the disc. . . typically after 6-7 attempts to get the CD to load it will then finally read the disc and will play normally, only to repeat this  process with each successive disc that I load. I think maybe I need to run a CD  to clean the laser? Any one have any experience with this issue? Or suggestion to resolve?
Russtafarian
  • Typical reaction to the music I play
Re: Luxman D-06 CD player
« Reply #1 on: 18 Dec 2012, 09:26 pm »
You can contact the Luxman distributor Phillip O'Hanlon of On A Higher Note.
http://www.onahighernote.com/contact/
maxboy00
« Reply #2 on: 19 Dec 2012, 01:43 pm »
Much thanks for the tip, I will contact Phillip in the new year!!
Russtafarian
« Reply #3 on: 19 Dec 2012, 09:22 pm »
He (like everyone else in the industry) is prepping for CES, so contact him ASAP or you'll have to wait until mid-January.
