The Dynaco PAM-1
0 Members and 1 Guest are viewing this topic. Read 998 times.
Mark Korda
    • Dawkus
The Dynaco PAM-1
« on: 16 Dec 2012, 08:49 pm »
Hi Tube Nuts,I may be insane,but want to try and get a couple of Dyna PAM-1's souped up and running.I have the Dyna Mark3's needed with the octal tube socket that provides the PAM's,mono preamps with the heater voltage.What I want to know is it possible to take the tone controls and the loudness switch out of the circuit?I found a copy of the manual on line and am going to try to post it with this question.It has a real big picture of the lay out plus the schematics and all the other info.If any one has an idea,I would love to hear it....thanks....Mark Kordahttp://www.the-planet.org/dynaco/Preamplifier/PAM.pdf
JakeJ
Re: The Dynaco PAM-1
« Reply #1 on: 16 Dec 2012, 09:34 pm »
Mark,
You might consider posing the same question in The Lab circle, or cross-post a link to this thread.  Just an idea.
Mark Korda
    • Dawkus
« Reply #2 on: 16 Dec 2012, 09:53 pm »
Hi Jake,thanks,I will post that at the lab....Mark
