0 Members and 1 Guest are viewing this topic. Read 3703 times.
Double drywall provides mass, which is different from isolation. Isolation reduces sound transmission from one side of the "wall" (or ceiling) to the other. For instance, if you have a 2x4 wall with double drywall on each side, you still have a direct sound transmission path, through the drywall, through the studs, and through the other drywall. I don't technically understand what greenglue is doing, but it's not going to take the place of isolation.
I will be building a new home with dedicated audio room. I pan on doing staggered studs along connecting walls for isolation with double drywall and green glue.Question, is it beneficial to treat all four walls and ceiling in the room with DD and GG if isolation isn't an issue on 2 walls and ceiling?Im not sure if DD and GG help provide to a dead room or strictly isolation?Thanks
On the other walls, if they're free standing and NOT tied to another room on the other side, no need to stagger the studs but yes, the double drywall still helps with isolation.
Hello Nick 77, Adding to Brian's excellent words, you want (if possible) all of your surfaces to have a similar acoustical "footprint" in terms of transmission loss, impedance and the spectrum of the reflected energy within the room. Next, I have been able to document the "bass trapping" benefits of GG with (2x) drywall and it is indeed a great benefit below ~80Hz. Simple suggestion then: do double drywall w/ GG on all wall and ceiling surfaces. This is a great start to an excellent dedicated audio room.
...could you, when time allows, please elaborate on the "bass trapping" benefits of GG....Cheersblutto
