Korg DAC-DS-10
0 Members and 1 Guest are viewing this topic. Read 8087 times.
hddoc
Korg DAC-DS-10
« on: 12 Dec 2012, 08:09 pm »
Importable from Japan for ~ $600 including shipping, the Korg would appear to present the least $$ alternative for playback of DSD files.
http://www.korg.co.jp/Product/Audio/DS-DAC-10/
Mac DSD compatibility is coming in February http://www.korg.co.jp/News/2012/113003/
Does not appear to use asynchronous usb?
Anyone tried it out or have any further information to share?
ted_b
Re: Korg DAC-DS-10
« Reply #1 on: 12 Dec 2012, 09:02 pm »
My friend, Todd Garfinkle, producer/founder of MA Recordings, is helping me get one to try soon.  He sees it as a possible entry into DSD for many folks.
wisnon
Re: Korg DAC-DS-10
« Reply #2 on: 12 Dec 2012, 10:48 pm »
Is it Async?
ted_b
Re: Korg DAC-DS-10
« Reply #3 on: 12 Dec 2012, 10:50 pm »
No idea yet.
AdvoCat
Re: Korg DAC-DS-10
« Reply #4 on: 13 Dec 2012, 09:12 pm »
Thanks for keeping us posted!  I am leery of buying a DAC right now.  There are so many hi-rez formats, but none seem to be coming to the forefront in terms of mass marketing.
I'm easy to please, though.  All I want is a high-quality DAC that will handle all formats and all inputs, using only the most advanced technology and best components.  And inexpensive.
AC
hddoc
Re: Korg DAC-DS-10
« Reply #5 on: 25 Feb 2013, 03:49 am »
Review of the Korg website appears to indicate that the DAC-DS-10 does indeed use asynchronous USB... :D
wisnon
Re: Korg DAC-DS-10
« Reply #6 on: 25 Feb 2013, 04:54 am »
Link to the review???
Maxvla
Re: Korg DAC-DS-10
« Reply #7 on: 25 Feb 2013, 09:28 am »
I think he meant he looked (reviewed) at the site and found that it is asynchronous.
hddoc
Re: Korg DAC-DS-10
« Reply #8 on: 2 May 2013, 07:59 pm »
As of April25, the Korg is finally Mac compatible. It does use asynchronous USB and can be had for < $600...
jackman
Re: Korg DAC-DS-10
« Reply #9 on: 2 May 2013, 08:02 pm »
Interesting.  Has anyone tried this DAC?  I spoke with the guys from schiit and they said they would have a DSD native DAC coming soon.   Nothing on the website so I don't know how long it will take.  Perhaps it will be available as an upgrade to an existing design.
scorpion
Re: Korg DAC-DS-10
« Reply #10 on: 3 May 2013, 08:54 pm »
I bought from Japan - Rakuten Global Market - from a shop that took Paypal and sent abroad.
Price inclusive of freight was round $500 and with added Swedish Import VAT it became $600 but still a very OK price.
It works like charm with Korgs own Audiogate player for me both in XP and Windows 7. JRiver is also working but a bit more tricky in Win 7, but that's me.
Foobar is so far no success, but eventually I think it will work also for me.
Qualitywise I think it is very good value for the money. I have the Behringer DCX2496 in combination with SRC2496 to compare PCM-performance up to 24/96 and I think that the Ds-Dac-10 is if anything perhaps better than the Behringers. The people at dsdfile.com offer a strong recommendation for the Korg and they have  Meitner MA-1 to compare with regarding DSD playing.
/Erling
scorpion
Re: Korg DAC-DS-10
« Reply #11 on: 15 May 2013, 02:35 pm »
Now I have mastered all the players: Audiogate, JRiver and Foobar with the Korg DS-DAC-10 in Win7 and XP.
The trick is to connect the hardware first and install drivers from the directory where you have them.
In Win XP you will be prompted a couple of times for new hardware connected, then repeat the procedure and new drivers will be installed.
After that you can run the Setup program that will install the program for Korg USB Audio Device Panel and you are through.  :)
/Erling
« Last Edit: 15 May 2013, 06:40 pm by scorpion »
KGREK
Re: Korg DAC-DS-10
« Reply #12 on: 30 Jul 2013, 10:29 am »
Sure it does. With one small exception: annoying clicks when switching modes (2.8/5.6) under both Audiogate for Win7 and MacOS...
this_is_vv
Re: Korg DAC-DS-10
« Reply #13 on: 13 Dec 2013, 07:52 am »
How's this dac seems I can get one wanted to ask people revie in this
